Coleman Powermate Powermate 5000W Generator Logo
Posted on Sep 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wlile suppling power to my house with my 5000w coleman, through the 240 oulet, with the main house breaker off, the power came back on. i shut down the gen and opened the house breaker but forgot to unplug the gen.then i heard a noise from the gen and puled the plug. now i can't get any power from the gen.any solutions or have i got the gen burned out
Anonymous
Level 3:
  • Coleman Master 43,501 Answers
  • Posted on Sep 05, 2010
Anonymous
Coleman Master
Level 3:
Answers
43501
Questions
0
Helped
10844782
Points
101584
Yes, you killed the diodes in the generator...they can be replaced by a generator repair shop... happens all the time...
heatman101
  • Denise Hoover
    Denise Hoover Jan 29, 2017
    can i replace the diodes my self and where are they located on my gen
  • Denise Hoover
    its a
    coleman powermate model PM0612023
240 volt output of 3500 watt powermate generator measures 140 volts
Bad capacitor in the alternator field or a short in the rotor / stator
Want to add 240volt outlet to generator
You CANNOT do this, USA 240V is derived from a poly phase scenario, IE 120V line to neautral and 240V line to line, UK 240V is derived from 1 line to neutral it will not work unless you power a transformer
I have a powermate 5000, it is putting out 330 volts on the 240 side/165 on the 120 side? what could be the cause of this?
There can be nothing but a bad voltage regulator in the end of the generator. They are getting harder to find. Robert
We have a power back generator 5050 watt we are trying to install the cord to plug into our house, what size cord do we need
If you are wanting to connect using the 120/240 outlet, I would use a #12 gauge 4 wire cable. If over 25 feet, then I would use a #10 gauge. The wire size will make a difference, so that is why I am offering the two sizes. Please make sure that you have a transfer switch if you are connecting to the panel. This will prevent someone from getting seriously hurt or killed.
thanks Joe
220 appliances in house all out.lights up but either dont heat or wont bake .lightning could be culprit but never lost tv reception.dryer runs ,no heat.water heater out.stove lights up wont get hot.shut...
Sounds like you have lost one leg of your power
Think of it like this
You an upside down "Y" at the top of your breaker panel
220 - 240 volts come in the Y and break in half 120 volts to each leg of the "Y"
A 220 Volt breaker straddles both legs a 110 volt breaker only contacts one leg
I suspect that you have lost one leg
Possibly at the main breaker ( top most)( main disconnect) in your panel
If you have a tester with the capacity to test 240 you can test the two top lugs where the main wire comes in Test them together That is one probe of your tester on each wire you should show 240+/- volts
Then you can move down through the panel 120 +/- on each leg
Hope this helps if you need more just let me know
Scott
2helpful
High voltage
Great, JP. Could I ask you to please rate my assistance. Thanks very much!
Charlie
2answers
Coleman 7000w gen. I have 120 on only one side of my 240 plug. I disconnected wire assembly from control box.. Could get 120 out of various combinations of the 4 wires but never 240. Should I be able to?...
At the wire assembly there should be 2 white and 2 black wires, a white and a black are the ends of one 110v winding. With the 2 white wires connected together you should get 240 from the black wires. This sounds like it is a problem with one of the circuit breakers in the 240v outlet in the control box, check them with an ohm meter.
Regards,
Carl
6helpful
3answers
No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Replacing eletric portion of Coleman PMA525500
my voltage meter shows 300volts instead of 230-240 and continues to trip generator breaker. What is my problem?
Top Coleman Electrical Supplies Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
john h
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
