Bosch Axxis WFL 2060 Front Load Washer Logo
Posted on Apr 07, 2017
Bosch Axxis After a washing cycle is done a door lock is not being released. I hear a periodic sound at the lock area (attempts to unlock?). Tried to unplug the washer, didn't help. Went through each position on a mode dial and suddenly the lock was released. Thought it was a glitch and set another washing cycle. This time I tried “worm”. When I pushed a Start button, nothing happened. I switched to “cold” and it started normally. After the cycle was done a sound indicator was wrong (instead of "finished" it played "ready", the door couldn't be unlocked again. Got it open gust like in the first case. Would appreciate an advice. Thank you.
4 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Apr 25, 2007
SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Anonymous
  • 589 Answers
  • Posted on Jan 11, 2008
SOURCE: Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
uniman9310
Mike
  • 190 Answers
  • Posted on Jun 03, 2009
SOURCE: remove bosch axxis 2060 washer motor
Remove the back panel to get to the motor which is at the bottom at the back. Notice two bolts holding the motor into the mount. Remove these two bolts. Notice the back part of the motor is sitting in the mount with black rubber washers. Carefully, pull the motor forward, and this will be abit hard. You can take a flat head screw driver and tap down (in between) on each front plastic washer and the motor will slowly come forward. Becarefull because there is a wire harness still attached to the motor. You have to take wire cutters and clip the placstic band holding the wire harness to the motor. Then grip the harness and wiggle it free. Then remove the single wire also. Putting the belt back is a bit tricky too. Make sure you put back the two black rubber washers and the two front plastic washers.
Anonymous
  • 414 Answers
  • Posted on Nov 23, 2011
SOURCE: washing machine bosch maxx 7 varioperfect
Sounds like have inadvertently activated the child lock. To deselect you need to press and hold the start button for approx 5 secs or until the key light goes out. Hope this helps, please let me know if this works or if you need further assistance.l
Door stuck closed after wash is done
If the water in the machine is above a certain level a fail safe on the door lock will not allow it to be opened. Check the filter, make sure the machine has completely drained. Obviously, there may be a problem with the lock itself but try this first.
All the best
My Bosch front end washing machine will not start a cycle. Door is closed tightly and when I push start/pause red light comes on & immediately goes off-this happens every time I push the start/pause...
My Bosch washer turns "on" and water runs but it does not spin or complete wash. I hear the machine "clicking" as if it is attempting to to function but no spin or full wash cycle.
2answers
Bosch wfl 2050/2060 washer door is jammed and will not open
talked with bosch rep-- said there is no manual door release
TURNED THE WASHER TO OFF, BEFORE FINAL CYCLE COMPLETED. DOOR WILL NOT UNLOCK.. TRIED ANOTHER FULL CYCLE, STILL WONT OPEN??
control knob has to be in a finished position before door will oped if it is and it still will not oped suspect faulty door interlock
1helpful
2answers
Bosch washer door won't open after wash is done
The door is probably locked, because the water is still draining. If this is not the answer, the the suction between the dor and the opening is too strong and you must get it weakened by a professional. There is one more solution, and that is to unplug the machine, reset it, and then try opening the door.
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
2helpful
3answers
Can't deactivate child lock on washer
Try: Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Water won't heat; door won't open at the end of cycle
I drain water from drum and read out say's open door and you hear door release active but door will not open.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
