SOURCE: Makita Circular saw 5007NB, the cutting depth
you can try spraying some lubricant on the bolt/roll pin and see if that frees it up that is about all i used to do to them
SOURCE: I cannot get a perfect 45 degree angle with my
When using the gauge on your saw it is off on the 45 degree cut? If so you might have to use a tri Square every time you want to cut a 45. Sometimes the lock gauge for the 45 angle may be off some. When you put a tri square on the board you cut it is not a true 45 even though the saw says it is?
SOURCE: I have a makita circular saw 5704r. I droped the
it is a retaining ring and you need a special pair of pliers to remove this. If the guard is sticking remove the blade and lube and try and blow out with compressed air, if other let me know and I will try and help.
SOURCE: The return spring for the blade guard on my Makita
there should be a hole in the housing towards the back of the saw, you can go to Makitatools.com and download a breakdown for this tool.
