Just purchased a Sony DVD recorder (model# RDR-HXD870) and am unable to watch and record at the same time due to not having the appropiate TV code for the supplied Sony remote control (model# RMT-D2480) for my analog TV (LG Super Slim model# 29FU1RLX). I have configured the antenae cables as such that I can watch both digital and analog programs (as per the manual). I know these types of queries are asked a lot but can you assist me in finding this code/codes?
070 147 126
085 139 041
079
try these codes closest i can get
if that doesnt work try 10
You're welcome try this codes as well, since its very hard to find a code for your setup but worth trying
003, 013, 012, 030, 046, 049, 050, 051
I've done research for this actually and cant find info on the way how you will set it up on an analog LG TV... Did you inquire from your manufacturer for the codes, because chances are it is nit going to work unless your TV set is Sony as well, Incompatibility issue is i think what you are having... Try contacting Sony instead just for info's regarding your setup.
0056 is the code for the LG TV.
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
IrishDruid
Most welcome. If you still have difficulties, please post back as to what you did, before you rate the solutions.
Just checking to see if your issue is resolved. If it is, please assign
a Fixya rating for the Expert whose advice guided you to a fix.
Cheers!
Hmm..the best advice I can suggest is that since you only bought this recently, best ask the store where you bought it for details. I am sure they will have a solution, and in case the device is defective, they will be able to replace it under warranty..
All the best!
Thank you for your efforts. Will let you know
how I got on tomorrow.
Yes, I'll try these as well thank you.
I tried all of the codes supplied but no joy.
My cable connection is set up so as to see both dogital and analog signals (as per the manual)i.e.- antenae cable from wall to digital in, cable from digital out to analog in and cable from analog out to tv.When I record to HDD (either recording digital or analog programs)and wanting to view another program on a different channel, the DVD recorder tells me "unable to perform this operation at this time".My system is set up for component video for which my tv readily accepts.I am at a loss as to what to try next....any suggestions?
Thanks mate. I'll keep you posted.
Checked with Sony and they said with my current setup (which was correct)and with the current capabilities of the DVD recorder it's not possible to record one program and watch another. It has something to do with having only one digital and one analog tuner.
I think you could possibly get around it by hooking up another device i.e. VCR or another tuner etc.. Anyway, I can't help but feel a tad disappointed cosidering the cost of this recorder.Unless someone else has a solution to this problem.... there end the lesson!
