SOURCE: I need drivers for sm-56 motorola modem with Win XP
Please go to the following link to download the driver:
http://www.softwarepatch.com/utilities/motorola-sm56.html
Alternatively you can visit this link:
http://www.modem-drivers.com/companies/694.htm
Thanks
SOURCE: Does Motorola SB5100 SURFboard modem block ports?
i dont see ruter for may Motorola SB5 100E
SOURCE: code 10 problem showing in on modem(device manager)
that is a problem with your DIAL-up modem which is the old style, use your phone and dialin type of internet connection. so basically if you're on high speed you dont really need it, you can right click and disable. if the modem is in a desktop in a pci slot, you can actually just remove it all together. code 10 means the device wont start either due to hardware failure or bad drivers...but again, its a dialup modem and oyu're on highspeed so you dont even need it.
SOURCE: Port Forward on Comcast Motorola SB5120
Are you just using a modem and NO router? This modem has no NAT so there is no way to open ports.
http://www.opendrivers.com/categorycompany/1365/197/modem-motorola-free-driver-download.html
i am sure it will help u....
best regards & best of luck..
even u can mail me at my mailing add- [email protected]
