I am assuming you can select water temperature on your machine. Simply hook up your pipe to the cold water feed on the machine, and leave the hot water feed alone. Always select cold water on the machine before beginning a load. If it makes you feel better, cap off the hot water inlet on the washing machine.
You will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end screws into the cold water supply and the hot and cold washer pipes screw into the double end. The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
Good luck,
John C
Hi from retired Englishman in France (it's 21:29!),
If your washer has 2 pipes for feeding water then one is for hot and the other is for cold naturally.
All washing machines have a water heating element in them- in case any hot water supply is not hot enough for its wash.
If you only have a cold tap you will need to purchase a 'Y' connector. This screws onto the cold tap supply (single end) and the hot and cold feed pipes connected to the washer screw onto the other two ends. The machine will now be fooled into thinking it has two separate feeds!
The machine opens the valve for the 'hot' water supply (which of course is cold) and the heats it up to the required temperature for the wash cycle. Afterwards, when the machine requires cold water for rinsing, it opens up the 'cold' supply (which is the same supply as for the hot water!) and is happy.
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
There is too much pressure on the cold feed, reduce the pressure on the cold by partly closing off the tap on the cold.
Or ensure the hot feed is fully open and not blocked, check if there are filters inline - remove the feed pipes at the washer end and look into the inlet valves - clear if blocked.
The inlet valve is common to hot and cold water with only a small pipe to fill the machine, the cold water is being forced back up the hot water pipe due to the pressure you can feel the pipe cool down after running hot then go to warm, if hot water is flowing the pipe will stay hot, if not then cold is going up the hot pipe.
This dishwasher should be connected to the hot water line under the sink. If it is connected to the cold line, you will have very poor cleaning. The hot water should be 120 degrees (F) minimum and less than 140 degrees.
There are 2 versions of the Hotpoint WD640, a cold fill only version, and a hot and cold fill version..
From your question, I conclude you have the hot and cold fill version, which requires a hot and cold fill supply..
I do not understand what you mean by leaking from top banch, perhaps you can clarify.
Dishwashers normally are hot or cold feed. My wife runs water at the sink to get it hot going in before turning on the dishwasher. You can use either cold or hot water. We have ours hooked up to the hot water side. They work better hooked up to the hot water.
