I would like to print roll-format labels without label gaps or label marks, with a very high degree of accuracy. The print goes onto spaces on a pre-printed label. Please help - we need to get the job done!
SOURCE: i-class cutting issues
You need to calibrate the printer using the instructions located in the
manual. This should be in area 5.2 of the manual. If you don't have the
manual you can download them at this address along with software
updates and firmware updates.
http://www.datamaxcorp.com/software/i-class/
Label printers are always finicky. I have strtix printers where I work and they give off wacky errors too.
SOURCE: Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
SOURCE: motor throtting
This error appears when the printer has worked for more than 1 hours continuous, and to protect the printer. Wait a few minutes for printer to cool and continue with your printing.
SOURCE: Dymo 400 was working fine, then I had to unjam
You probably didn't damage it, it sounds like you may have knocked loose the thermal printing portion (which is the most important part). There is no easy way for you to repair this but Dymo will usually do it for free under warranty. Their phone number is:
(203) 588-2500
