SOURCE: 1st Gen. Ipod Nano wheel control wont work
You have a bad component on the main logic board.
http://www.ipodrefresh.com
SOURCE: Ipod won't work unless plugged in to computer or mains
alison65,
good day, the only possible cause why your player can only power up using it's own charger or through pc connection is:
1) The connection of the rechargeable battery inside the player is loose or out of contact
2) The rechargeable battery itself is faulty
3) The connection from the charging line is loose or out of contact
most likely your problem is within the internal of the unit.
cheers,
mark
SOURCE: Ipod wont turn on. ive tried everything! none worked! HELP!
You will want to attempt to force the iPod into disc mode before restoring. This should solve your issue.
Toggle the Hold switch on and off.
(Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Please let me know if this did not resolve your issue. :)
SOURCE: White screen on my silver 120gb ipod classic
The white screen on Apple Products is never really a good thing.
You've probably heard of the blue screen of death(Windows) and the red ring of death(XBox), the white screen is referred to the white screen of death, normally not something you can recover from.
But try this anyway:
Reset the iPod:
If the reset doesn't help, then put the iPod into forced disk mode.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following
the next step. How exactly you check a charge on an iPod screen that
is completely white has yet to be revealed. But hey, give it a shot
anyway. Plug the iPod into a high-powered USB port, let it sit for 2
hours, then disconnect it. If you have a wall charger, plug in the
iPod, then follow these steps while it is still plugged in.
For a lot of people, this solves the problem. Connect the iPod to the
computer and (assuming it shows up) reset the iPod again to get it out
of Disk Mode. If at this point you still have the white screen,
restore the iPod using the restore function in iTunes under the Summary
tab (this will erase everything on the iPod and put it at factory
settings).
Don't disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Connect your 5th Generation iPod Nano to your computer with your iPod cord.
locate your iPod in My Computer(Windows) or the Finder(OSX)
Open the Folder titled DCIM then open the folder titled 000Apple.
The files ending in .mp4 are your videos. copy and
and paste or drag and drop these files to a folder on your computer.
Thats it! you can now edit and share your iPod videos with your Friends!
The rest of this step is just filler because eHow will not let me publish this article unless it has a certain amount of words in it. So i figured i would just write this long redundant paragraph at the end to satisfy the crazy supercomputer that runs this site instead of making my steps unnecessarily complicated and confusing you guys..
Read more: How to get video off a 5G iPod Nano ' eHow.com http://www.ehow.com/how_5604379_video-off-ipod-nano.html#ixzz11KHjGYNz
