Question about Yamaha Emx312s Stereo Powered Mixer Emx312sc
Faded out the sound and will not turn power up
  • Yamaha Master
  • 5,603 Answers
Make sure the STANDBY switch is not pressed. It will fade sound out on the first 8 channels and keep it off.
Posted on Sep 07, 2010
6ya staff
SOURCE:
Marshall Amplification Marshall MG2FX Guitar Combo Amp power turns on but no sound
Hi!
At this point, I would just take it to a tech rather than poke around in it. It sounds like the power section is the problem as you have guessed, but without the technical knowledge you'd be shooting in the dark. That particular amp is right on the line of being expensive enough that would be worth repairing, but you might do just as wel to check Ebay for another used one.
Good Luck!
May 21, 2014 | Marshall Amplification Marshall MG2FX...
I'VE A YAMAHA PSR S700. The problem is with it's screen. Whenever i start playing, the screen fades and then it comes and it goes and vice versa. This occurs almost two - three days a week. There...
Likely a connection to the backlight is being broken. Tap on the unoit and see if it pops back on. Illuminate screen with a flashlight and see if the characters can be seen when screen is faded. If they can, then the backlight is the problem... IF NOT then the display may be bad... This has been a problem and if you are under warranty, excersise it immediately... else replacement of the display is relatively expensive.
May 28, 2011 | Yamaha PSR-S700 ARRANGER WORKSTATION...
Guitar is very quiet
make sure its the guitar by trying in another amp, and if it is the guitar take it to a guitar shop, theyll figure it out
Mar 26, 2011 | Gibson 1957 Les Paul Jr Single Cut VOS...
Hi, I ordered my Adam a7x from america to Australia. When receiving them, i plugged in australian adapters (300/500volts). But when powering them up, unfortunately the light went on and then a...
Did you just use adapters or actual step-down transformers?
A lot of equipment today is 110/220 auto-switching, but if you get something built for 110V (120V, 100V, markings may vary) only, then you need more than an adapter, you need a transformer!
Mar 14, 2011 | Adam Audio A7X Powered Studio Monitor (7...
The problem with my marshall ma100h amp is that out of the box brand new it stopped working within a few days. Earlier I turned on the amp power switch and let it warm up. About a minute later I kicked on...
Brand new? Take it for warranty repair IMMEDIATELY... don't mess with it !!!
The only thing for you to check is that you did not turn on "STANDBY" as this shuts down the power amp and the capacitors will bleed off and sound will fade. Try switch in both states before complaining
ONLY use the amp in STANDBY for a brief period (20 seconds) to let the tubes warm up... Leaving in STANDBY for a long period straains the input filter capacitor. If you are done with using the amp, turn it off...
Jan 14, 2011 | Marshall Amplification Marshall MA100H and...
No Sound on my CTK 4000
See if you can hear any sounds via the headphones as a test.
Apr 20, 2010 | Music
My Line 6 Amp has a sort with the volume, the volume will be low and for no reason shoot up to about 8 or 9. how do I fix it?
Sounds Like You need a new volume pot you can buy them at radio shack, Best buy, Click Here to see it. Its very easy to replace if you have soldering experience if not it should be to expensive to fine somewhere to do it for you.
Hope this helps and if you have more questions let me know.
Sincerely,
Michael Scott
May 03, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
LOW VOLUME FROM RIGHT CHANNEL OF STEREO 1 SIDE OF SYSTEM
It seems like the speaker jack tip needs cleaning, or the contact has become bent away from the connector and needs to be re-aligned.  The Passport is a portable system, so after years of plugging and unplugging the speaker jacks may be worn.  Try using the "Stereo 2" connectors. You can also try cleaning the jack with electrical contact cleaner, and. a cotton swab.
Jan 07, 2009 | Fender Passport Deluxe 500watt Sound...
Yamaha Emx312s Stereo Powered Mixer Emx312sc Logo
87 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
