Pioneer Elite PRO-111FD 50 in. Plasma TV Logo
Posted on Sep 08, 2010
My Pioneer Elite PRO-111FD just shut off on it's own, and now won't turn back on. No green or red indicator light... nothing. Any suggestions?
Anonymous
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Sep 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
6717
Points
71
Check your power source (electrical outlet) and the power cable. If electrical outlet is ok, try using a different power cable (the cable that you plug on to the electrical outlet going to your TV set). If everything is ok but still no indicator light, call your technician there might be a problem with the TV power supply.
1helpful
How can I watch Netflix on pioneer elite pro-111fd
You will need to connect a streaming media player to the Pioneer Elite Pro-111FD. This can be your computer (make sure to set the HDMI input to PC, if needed) or a Roku or Fire (either the stick format or the box). Set the TV to the correct HDMI input and then access Netflix on the media player.
The Ethernet port on this TV is only for use with media saved to your local network. The TV cannot directly use the Netflix app or website. See the manual for details on the Home Media Gallery Server features of the Pro-111FD. The manual is available from Pioneer on the product page: https://www.pioneerelectronics.com/PUSA/Home/Plasma/PRO-111FD . The direct link to the manual is currently https://www.pioneerelectronics.com/StaticFiles/Manuals/Home/PRO-151FD_OperatingInstructions0905.pdf .
I hope this helps.
Pro-111fd 8 RED blinks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
Sanyo tv model dp50747 keeps shutting off automatically
Short circuited PCB inside it. Any one printed circuit board will have short circuited component/s; in turn draws tremendous current during switch-On, and the short circuit protection circuit inside the TV activates, and shuts it down, is happening now. Contact any service technician, or authorized service centre for Panasonic. This is not a user repairable fault.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Pioneer Pro-111FD does not power up and blue light keeps blinking 8 times
8 times blinks denotes a cooling fan failure. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
1helpful
TV keeps shutting off automatically
Since your plasma is less then a year old, I would suggest to contact the manufacturers to get it fix under warranty. If the plasma keeps shutting off by itself, that is not normal and should be repair.
Pioneer elite pro-530hd tv---no picture at all!
I have a 532nd 53 that shuts off and red stand by lite comes on in the back. If you wait awhile and unplug it and plug it back in it will come on again and then shut off after an hour or two
4answers
Problem with pioneer elite pro-99
your tv's hardware might got the problem. this should fix with an expert technician that they have a tools for fixing this problem. if repairing will cost you alot then i suggest that you have to buy a new tv insted of repairing your old tv. hope that helps!
CHARCOIS
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
