Most bluetooth headsets or earpieces need to be "paired" to the phone before the can be used this usually just means you need to put both devices into pairing mode search (scan) from the phone select your earpiece in the list and enter a security code to complete the initial connection (pair) after that the earpiece can just be turned on and off with normal use
SOURCE: Connect trueblue bluetooth headset to Samsung Eternity cell phone
I had the same poroblem. I turned the phone off and then restarted it. That worked for me. Try to make a phone call and see if you can hear it on the Bluetooth.
Also... compliments of Best Buy Troubleshooting -
Bluetooth Troubleshooting: Phones & Headsets
Problem #1: Headset and phone are turned on, but you don't hear anything in the headset, i.e., there is no dial tone.
Action #1: Make sure your phone is Bluetooth-capable. If it is not: A. Buy a new Bluetooth-capable phone. B. Purchase a Bluetooth adapter for your non-Bluetooth phone. The adapter will allow your phone to interact with a Bluetooth headset.
Problem #2:
It's a Bluetooth-capable phone and Bluetooth headset, both are turned on, but you still don't hear anything.
Action #2: Make sure your phone, headset, and, if necessary, adapter are fully charged before attempting to synch the Bluetooth connection between the two devices - in many cases a blinking blue light will indicate the headset is charged.
Problem #3:
Everything is charged, but still not working.
Action #3:Before two Bluetooth-enabled devices can communicate with each other, they need to be initially synched up to each other - also referred to as linking or pairing.
A. Find "Communications" or "Connections" on your phone's menu screen and explore within to locate "New" or "Bluetooth."
B. Push the main button on the headset until the light shines solid blue and is NOT blinking. C. Select Bluetooth on phone menu. Within Bluetooth you may need to select and highlight "Devices" or "Find Devices" (depending on where you are, there may be other Bluetooth devices available).
D. While the headset light is solid blue, open the Bluetooth link (or Find Devices) on your phone's menu screen and scroll through until you locate the headset you wish to synch up to. Your phone will automatically begin searching for Bluetooth devices within 30 feet of itself.
E. After a short period of time, your menu screen should say "connected" or "devices paired". Make sure you click or select the device name to finalize the connection. If you have successfully paired the two devices, you will hear a dial tone in the headset. Congratulations! You've joined the Bluetooth world.
Note: After a couple of minutes showing solid blue, the light on the headset will start blinking; you want to pair up the phone and headset while the light is still unblinking. This is important. If the light starts blinking before you can complete the connection, you will need to turn the headset off and on and start over.
Problem #4:
You've followed all the instructions in this guide, and your Bluetooth connection is still not functioning properly.
Action #4: Take out your manual and carefully reread the section on synching up Bluetooth devices. If you still can't get things properly connected, we suggest you call the manufacturer regarding this issue.
Motorola: 1-877-MOTO-BLU for troubleshooting, or www.hellomoto.com
Jabra: 1-800-327-2230 from 8 a.m. to 8 p.m. EST for technical support; or www.jabra.com
I hope this helps.
I regret that I cannot give you device specific instructions because you have not provided device model numbers we can look up. But I hope my generic answer will help.
