Question about Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. HDTV LCD HDMI input not working
I have a 32in Vizio LCD HDTV that I bought from Costco in 7/2006. The HDMI connection was working fine with HD cable & HD DVD player - up untill about a month ago. The RCA connnection/cables work with reg. TV, but HDMI connection doesnt work - we get a blue screen with sound. We're not getting true HD picture. We've taken the TV to an electronic repair shop & they've had it for 2 1/2 weeks. They at 1st told me the I/O board was defective...and had to order a new part. The received new part on Monday & TV was still having HDMI issues...they replaced it with another I/O board & same issue was still ocurring. Now they've told me that they've contacted Vizio & Vizio research told them that my TV is an older model & they don't carry parts for it & refered electronics shop to 3rd party repair company - Repair Solutions. Electronics shop told me they are waiting a call back from Repair Solutions to see if TV needs special HDMI cables or a software upgrade. My question is has any one heard of the HDMI connection going out & should i think about getting a new HDTV since electronics shop is baffeled? Thanks
  • 5 more comments
  • toohighpsi Jul 01, 2008
    I appear to have the same issue on my Vizio L32HDTV10A Serial Number ASLEABAG343341
    I believe the HDMI connection
    on the TV has gone bad. I've always used the HDMI cable as my primary
    connection and recently lost the picture (still had audio, just now with a blue screen). I removed the HDMI cable and had
    it checked on another HDMI setup (different TV and Cable Box). I also
    verified that the cable box HDMI connection was working (again, by
    using the box and cable with a different TV).
    Thanks for any help.
    Tom
  • alexr54 Nov 06, 2008
    I cant find any software downloads for the TV. Can you please point me in the right direction?
  • macg801 Dec 21, 2008
    I have had this same problem with an Oliveia brand hdtv. I have test the box with a different t.v. and it worked. When I hooked up the t.v. with a different box it gets a purple picture with no audio. My t.v. works with other connections just not the hdmi. I believe the hdmi connection has gone out...and in the cases of no name brand t..v.'s such as vizio and oliveia, the cost to fix the problem is atleast half the cost of the t.v. With current hdtv prices, just buy a new t.v.
  • Anonymous Dec 28, 2008
    My vizio 32L shows a yellow tint in picture and the white lines are yellow when I use my HDMI cable. Regular cable works fine for my general cable tv. It just gets yellowish when I try to use the HDMI on my ps3, HDTV, and Blue ray. Anyone know what might be wrong?
    I have a vizio L32 TV. The color on the picture turns yellowish and the white lines turn yellow when I use the HDMI port-cable. It does it with my ps3, hdtv, and blue ray. I can't figure out what is wrong? The port? Is there a software upgrade for my tv? When I use regular cable my picture is fine.
  • megnme2 Jan 22, 2009
    My HDMI connection on a Pioneer PDP43A5HD was cracked by the cable installation tech. Any ideas where I can get this repaired/how much it will cost? Original vendor is out of business. Thanks.
  • Freway01 Feb 21, 2009
    I have the same problem. I notice that the DTV (digital TV tuner) isn't working also (it use to). All analog and AV connects work fine.
    Anyone find a fix for the HDMI & DTV problems?
    Tom H.
    Problem Solver:
  • 10 Answers
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
Posted on Oct 10, 2009
  • 1 more comment
  • oj75 Nov 28, 2010
    I read Jerimy_smith's response and thought it sounded pretty stupid. How could this possibly work? We tried it anyways. IT WORKED !!! Thanks for this brilliant, yet unbelievable, solution
  • Nathan Vue Nov 10, 2011
    With all these problem with the hdmi port. Vizio should recall to fix this problem. It is the best way to keep customers happy. Otherwise customers will switch brand and soon they will be closing their door forever.
  • kyle963
    kyle963 Jan 23, 2013
    I have the L32. Year 2006 model and had the HDMI problem and the above info worked and save me some $$$. Thank you for sharing....
I have had my tv got blank a couple of times.. at the HDMI connection.  Seemed to be software.  I unplugged the HDMI and turned off and unplugged both devices (tv and dvd) then turned them back on.. problem solved.
Posted on Jul 02, 2008
  • thescotts458 Feb 23, 2011
    unplugging everything worked!!
    New Friend:
  • 129 Answers
THATS A SOFTWARE ISSUE , IF YOU CANT GET THE SOFTWARE UPGRADE LET ME KNOW
Posted on May 16, 2008
6ya staff
SOURCE:
My Connections From VIZIO 1080P & Laptop using HDMI But Is Not Working
If the firmware to HDMI is not installed, there will be no HDMI reception, although all the other inputs are OK. Contact the authorized service center. Software upgrade/re-install is a skilled work.
Jun 09, 2014 | Vizio 47 120Hz 1080P Full HD LCD HDTV
My VIZIO 1080P cannot connect thru HDMI cable To My Laptop
Just use the VGA/PC input instead. It requires an rs232 cable. It's HD and will automatically adjust the proper settings for the display.
Jun 08, 2014 | Vizio 47 120Hz 1080P Full HD LCD HDTV
Connect Dell Inspiron 6400 to VIZIO E601i-A3 60-inch 1080p LED HDTV using VGA Connector
When you connect the vizio try changing the resolution settings on your laptop to see if that makes a difference. Could be that your video card output is not really compatible with the higher requirements of the Vizio.
Sep 20, 2017 | Vizio 60" E601I-A3 Full HD LED-LCD TV
When I plug a brand new HDMI cord into my Vizio VA26LHDTV10T it says
Have you used the input display ie usb freeveiw hdmi avi ect because your tv will have a input display ?
Sep 07, 2012 | Vizio VA26LHDTV10T 26" 720p LCD HDTV
Where do to plug in the cord to connect the tv to the DVD player?
Hello
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
Apr 24, 2011 | Vizio 42 in. LCD TV
Hdmi on vizio hdtv input says not support
Ur board is shorted it cost alot to replace the board for just the HDMI port to use.Must change the board or use the S-Video port.
Aug 17, 2009 | Vizio VW22L 22 in. LCD HDTV
Vizio lcd sreen fading out.
Well time will tell if this is a true solution but I experienced the same issue. Originally I was able to get the TV to work by turning it off and back on.
After some research I notice the the Vizio FAQ mentions a similar issue for which the solution is to unplug the unit for 3min.
After calling Vizio, they suggested that under the menu option Setup, Picture, Advanced Video Features, I should try turning off Advanced Adaptive Luma and Backlight Control.
Aug 14, 2009 | Vizio VOJ370F 37 in. LCD TV
Cant see full picture w/ Vizio 32in HDTV
You would look for a format button on your remote.
Dish Network: bottom left the asterisk "*" button
DirecTV: top left, second from the top labelled "format"
Cable remote: look for format, zoom, or aspect ratio
Pressing this button should scroll you through the options.
Apr 16, 2008 | Vizio L32 32 in. LCD HDTV
Green screen vizio lcd
My 37" vizio I bought in Dec 2007 did this (green screen at start-up on all inputs). At first it went away by itself after you left the unit on for 15 minutes, but then 2 days later the whole thing DIED. Luckily Costco has a 90 day return policy on TVs.
Vizio tech support suggested this (before it died that is):
Please try to reset all setting and then to see if the problem is solved. 1. Press the Menu on your Remote Control;
2. choose Set up on the OSD;
3. then choose Reset All settings;
4. Press the Exit on your Remote Control to remove the OSD.
Nov 27, 2007 | Vizio L37 Television
Vizio L32 32 in. LCD HDTV Logo
16,042 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
