The free nemo pdf to word converter could help you solve the problem.
You can easily change the pdf format of scanned pages and edit it in the word Microsoft program. Just go to MS word and chose the file you want to change and edit. When you select the pdf file, it will ask for converting to word, click yes.
There are many useful PDF converters that can convert PDF to Word without Microsoft Word programs such as Bitwar PDF Converter!
It is the best online PDF Converter you can find on the Internet with all the useful PDF tools that PDF users need such as:
Perform Online PDF Converter
All users need to download the PDF Converter here and install the on the Windows system. After finish installing the software, continue with the simple steps below:
Step 1: Select the PDF to Word, PDF to Excel, PDF to PPT, PDF to RTF, PDF to WPS or others from the Convert from PDF menu.
Step 2: Click Add PDF File or drag the files into the software.
Step 3: Click on Convert to start the PDF conversion.
Step 4: When the PDF conversion is complete, click Open File to preview the new file.
To change pdf format of scaned pages and edit it in word microsoft program, you only need a PDF converter for you. Here this list of Best PDF to Word Converter for 2018 might give you some idea. What is the Best PDF to Word Converter for 2018 Download Address Included
The pdf converter program does an exellent job of retaining the original files layout
and graphics. You can drag&drop the PDF files which you have
selected for conversion. It is easy to use. Just need 3 simple steps: load PDF files» choose the output format for conversion» begin to convert files.
The mac version here: click
Advanced PDF To Word is a professional converter for batch converting PDF documents to Word documents, which can be edited as required. all the original text font, images, graphics, hyperlinks, layout and formatting are kept intact after conversion. Advanced PDF To Word only takes seconds, and even faster, to convert a huge PDF file to .doc without any quality lost. What's more, it supports batch conversion to save your time. It is the only product which is able to convert Password-protected PDF files to word documents successfully .
http://www.advancedpdfconverter.com
Hey if you have scanned it as a jpg so you can not do anything, but if this is scanned as text when you highlight text in adobe and then copy this into Word. If you want to edit a pdf document you need the full verson of Adobe Acrobat. Or you can dowload AnyBizSoft PDF to Word Converter. http://www.anypdftools.com/pdf-to-word.html
http://convertpdftoword.net/
txexixs
