Cell Phones Logo
Posted on Sep 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How change dictionery option. My dictionery is now on T9. When I messaging it is appearing like words.I want to change it into normal messaging. how can i change it
Anonymous
Level 2:
  • Expert 94 Answers
  • Posted on Sep 12, 2010
Anonymous
Expert
Level 2:
Answers
94
Questions
0
Helped
25713
Points
324
Hold down the * button the you can find the menu appear in which there is an option to turn off the t9 dictionary.....all the best.happy messaging:-)
How can one type with a normal typing keyboard rather than hitting abc for a c?
If your phone only has the numeric pad you can change the setting from "abc" to "T9". T9 is a predictive texting mode, so if you wanted to type the word "hello" you would just press the corresponding numbers 1 time, for example: 4(gHi)-3(dEf)-5 (jkL)-5(jkL)-6(mnO), so you would only hit 4-3-5-5-6, if the word is not the first word displayed you can hit the next key which is usually either * or # depending on your phone. The T9 setting is usually changed by again hitting either the * or # key, or sometimes 0. It is also sometimes selected on the texting menu from within the message.
Learn how to use T9
Sep 06, 2011 • Cell Phones
2answers
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
5helpful
How do i delete words that have been added to the dictionary on the tocco ultra
You can't delete other than by reflashing the phone or some phone RESETS will reset the dictionary You can however "lower" the word you want to ignore in the T9 word option list.
This is done by typing the same letters as the word you dont like such as "WOT "and repeatedly replacing ( i,e. choosing it from the options) it with the word you do want say "YOU".
So start an SMS message in T9 mode and repeatedly type "wot" and replace it with "you"
you you you you you you you you................
save the message in drafts
start a new message in abc mode the type
save to drafts..........
start a new message in T9 mode and Viola - "you" should be above "wot" in the word option list.
The T9 dictionary has "learned" your preference.
Regards.........B
Aug 02, 2010 • Cell Phones
4helpful
2answers
Is there a T9 dictionary on the SE Satio and how do i switch it on
Hi, when you coming to messages you have an option of changing the keybord. Change to alphanumeric and then long click on #, this will change from capital letters to numeric and to t9
2helpful
How to take t9 off boost mobile i570?
There is no option on the i570 to actually " Turn off " T9, but there is the option to switch from "Word" to "Alpha" with eliminates the annoying T9 from interrupting your text message. The way you do this is by creating a new SMS text message or "Reply" to an existing message in you inbox. Either way works. Once in the new message window you want to press the "menu" key you will see "Entry Method", you then just want to select "Alpha" instead of "word" and the T9 will no longer be active.
Nov 16, 2009 • Cell Phones
1helpful
How do I delete auto text words from dictionery Samsung GT 8300
No, u cannot delete the auto text word from the build-in dictionary function name T9, but u can disable this auto text mode.
When open a new text message, just press the icon ABC to change the mode to ABC, T9 or number.
YBC (/\)
Outlook Express is using incorrect dictionery
Open Outlook Express, click on Tools>Options and the Spelling tab. At the bottom is the dictionary that is being used. You can change it to English...
Please rate this solution
11helpful
2answers
Predictive Text
To get predictive text on or off on the LG Shine go to:
>Menu
>Messaging
>New Message
>Text
>Options
>T9 languages
>T9 on/off
2helpful
Changing language so i can text message
open a creat new tex message options and look for somethin like edit T9 dictionary, input language input type failing this come out of the thx message to messages and find settings and repeat above
Text messages
u hav to press on the part of the screen where ur typing till a faint down arrow comes there. press that and change the word. if the word is not there you must create it in the t9 function. to create a word from scratch press on the part of the screen where your typing a few times and the press options then press create word.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
