My camera is frozen. I can turn it on and see thru the viewfinder but the shutter button does not work nor any other button for that matter. I cannot switch to the LCD screen but it will turn on in the view memory card mode but cannot advance or delete the fotos. No buttons work. It seems it just needs to be reset somehow.
SOURCE: Problems with my Panasonic Lumix Digital camera
let me explain to you guys, these cameras are slim line cameras and if dropped or mishandled it is going to give problems. you cant blame the camera if you are not handling it corectly.
SOURCE: dust inside lense
Open the Lens Assembly and clean it but do it, in case you know how to do it.
SOURCE: Lumix DMC-FX01 Buttons not working
Remove the card and battery. Clean the battery contacts inside camera with a cotton swab lightly dampened with rubbing alcohol. Be sure battery is charged. Press all buttons on camera. Insert card and then the battery. See if it works. If you can now get into the setup menu, you can do a reset from the menu.
SOURCE: Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
I have the same issue. When I press the shutter button, picture will not take. I can only review the most recent picture taken but no others. Actually no buttons work on the camera. Neither does the zoom. The only things that do work are the Mode Dial and the On/Off switch.
Any advice ?
contact me at [email protected]
exact same problem - camera basically frozen
