SOURCE: hp psc 1510 - only want black ink
Hi Manavoc,
I will explain you the cause for it.
It prints in yellow first and then override with black for better quality. This is the reason your color ink gets empty.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00308490&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Have a great day!
SOURCE: Canon MP500 Printer head error
Print heads for nearly all printers are rated at 2 years. You may also need to clean the tube from the resevoir at the ink supply to the cartridge and clean the working resevoir on the cartridge as well. If you are up to this challenge there is a how-to at your manufacturer's web site or you can have a tech do it. Most people, when they realize how inky you will be getting choose to have a tech do this.
It is best to use 100% denatured alcohol, from your hardware store, to clean these parts and tubing. But, you must take precautions.
DO NOT USE DENATURED ALCOHOL UNLESS YOU READ AND FOLLOW THE DIRECTIONS ON THE BACK OF THE CAN.
I'm not kidding about the precautions. I do all this stuff outside when there is a breeze in the air and then I stay up wind of my work.
If you have any questions whatsoever just feel free to comment back to me.
Regards,
Worldvet
SOURCE: installed new ink & it says "Print head is not installed" -
try to unplug it and plug it back in
SOURCE: canon ip 1880 - colour cartridge problem
no if ur filling the catridge more times the printer going to damage
SOURCE: Canon MP470: "Print Head is not installed. Install Print Head"
Some printer brands have a cute scheme that reads a "new" cartridge as good, but the refilled one has a small fuse link that is burned out by the printer. Try factory new cartridges. Unplug the printer power for a bit to reset the printer.
