There is no more convenient and effective troubleshooting of a machine other than knowing first the exact model number of the machine. We may not be able to help you determine and address the problem unless the exact model number of the machine is stated explicitly. Troubleshooting may push through only when the exact model number of the is known. You may have stated it in your previous exchange of messages with a fellow expert, if there's any, but I cannot view the transcript of those.
You
don't
have to accept or reject
and rate this post
to add information
or post comments and follow-up questions should you need further
assistance. But accepting a solution does not
stop you from communicating
with an expert. You may continue communicating with the expert as
long as you need assistance regarding the issue stated herein.
Remove the top panel to access and check the connections on the control and the fuzzy logic display including the wiring connection at the pump itself. Reseat the connections several time to clean off dirt and corrosion built-up in the connectors and the terminals. Make sure the wire harnesses are fully inserted. There seem to be an intermittent operation of the machine particularly the pump as stated in your problem description and indicated by the pump eventually emptying the water after turning on and off the machine. Turning off the machine resets it but unplugging it for at least an hour may reset the machine completely and resolve the intermittent operation problem.
The machine is a fuzzy logic top loading NEC NWTL656.
Thanks
