Daewoo wash machine air power 7kg Model DWD-F1013. Won't spin? Have cleaned out all the pipes and the filter it was full of keys and loose change. Can you advise? Do we need to locate a new control board for it? many thanks.
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
first does all of the water pump out when wash cycle is done? if not then check your drain lines and see if pump is coming on. if it is not then it wont let the washer spin,
