Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Sony bravia hi mate have a sony bravia 50 inch rear projection tv iys only about 14 months old it wont come on .when turned on after about 30 secs switches itself off red standby light comes on and flashes 3 times of a sec 3 times off a sec and so on ,theres no light to suggest its the lamp H E L P
  • poppy84 Mar 29, 2009
    kdf-50e2010 my 50inch sony bravia rear projection tv turns itself off about 5 seconds after we turn it on and it makes a popping sound, the standby light flashes 4 times, what do the 4 flashes mean???? please help!!!!!
  • juliewalker3 Apr 20, 2011
    ive got a 50 inch sony bravia kdf_e50a12u when i turn it on it the green light comes on then it flashs red three time and thats it please help
  • 320 Answers
What model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
Posted on Oct 19, 2008
    ive got a sony bravia 50 inch rear projecter no picture or sound when i turn it on the green light comes on then it flashs red three time its had a new light i dont know what to do now
  • Anonymous Apr 20, 2011
    Make sure the lamp is completely plugged in and that the lamp cover is correctly closed. It is possibly the switch on the lamp socket may have been damaged, if your set has a lamp socket switch. I would need the model number to know that
    New Friend:
HI I HAVE A SONY BRAVIA 55 INCH REAR PROJECTION TV MODEL NUM: KF-55E200A. 1 DAY IT JUST MADE A POP NOISE AND THE SCREEN WENT BLACK,NOW WHEN I TURN IT ON IT MAKES A BUZZING SORT OF NOISE,THE SCREEN IS BLACK AND A RED LIGHT FLASHES? WHAT DO I DO
Posted on Oct 01, 2010
6ya staff
SOURCE:
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
I have a sony bravia 50 inch rear projection tv. model KDFE50A12U .It has been working fine with no hints of a problem,yesterday when i switched it on the power light started to flash and the fan,bulb and...
i have a sony bravia 50 inch rear projection tv kdf 50e2000 the problem is it fail to switch on when it did it swicth on had black line cross the screen
Apr 01, 2009 | Sony Televison & Video
Sony Wega 50
Usually this is a classic lamp problem, but it could also relate to a defective lamp ballast (power supply).
Now if you are replacing lamps frequently, it's likely the lamp isn't getting enough airflow to keep it cool. If you don't get the airflow issue solved it will take out the thermal safety fuse near the lamp and your set won't come on and the power light will blink red 6 times repeating itself until you unplug it. Some lamp fans are so deeply nested it takes a trained tech to get them out. Dusty environments are bad for TV's with fans in them, especially projection types.
Nov 09, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
RCA 50in Rear projection TV Turns on and off every 30 seconds-New
if u have only had it a month it should be under warranty get them to repair it
Sep 21, 2008 | Mitsubishi VS-55609 55" Rear Projection...
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
1,655 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
