Hello, friend! I happened to see you with this problem, I also meet this error about my cell phone, I get many help from this forum, and also bought many DIY repair tools from china supplier , and vipprogrammer help me fix this error. maybe you can try it.or contact ther WhatsApp:+ 8615986801289 website: http://www.vipprogrammer.com. They've solved my cell phone problem and I hope it will help you with your mobile phone trouble.They have professional Screen repair tools.
They are free to consult, I hope that the programmers I recommend can help you.
SOURCE: SIM card registration failed
You might have filled up the memory to the brim and the phone doesn't have enough to switch on.
Try reformat to original settings. anything you stored on the phone will be lost.
How to reformat your phone, first turn it OFF. Press * 3 send at the same time and keep them pressed while you turn the phone on.
Give it time to work.
Remember, do not let go the 3 keys until you see the formatting screen.
After a few minutes when the process is over, your Nokia N70 will be back to the original delivered system.
SOURCE: I can't turn on my phone ><
Try to format your phone, use the following steps.
Switch off the phone. Press phone on again. Now hold down the following three buttons: Green (call answer) button, (* )button, and '3' button. Format is complete when you see 'Choose Country' option. All your data in phone memory will belost, but your data in the memory card will still be there. if this does not work, take your phone to the service center and have it flashed
SOURCE: cannot access SIM contacts or SIM card
If you go into menu and press contacts, options, select sim contents, sim directory and the go back to options and mark/Unmark, then select mark all. Your phone will automatically tick all the numbers on your sim. The last thing is to press options again and copy to contacts.
Let me know how you get on with this but l guess this should fix your problem.
SOURCE: not able to copy contacts from my nokia 6060 phone to sim
Only reason that could be there is either your phone is protected with password or the sim is protected. Remove the protection and then try.
