Was watching TV, loud screaming sound came from tv with 1/2 picture black other scrambled. Turned off tv right away. When you turn it back on all you get is a pink screen, not solid but "fuzzy" like when you cant get a channel. Also at the top left is "255" and a heart. When any buttons on remote is pressed, "menue locked" is the response. Can some one help ? Thanks
The controller eprom is in a fatal error and cannot be repaired. The pink indicates that a channel in the LVDS interface is gone and that cannot be repaired. This most likely is caused by a failure in the LCD module itself which then shorted out the driver on the main board. If your unit is under warranty, take it in as the LCD panel itself should be covered.
Good luck
