Question about V, Inc. Vizio P50HD Plasma Television
Another dead Vizio... P50HDM
My Vizio P50HDM went out last night, and now I have no video or sound.I wasn't in the room at the time, so I'm not sure if it made the "Pop."
If I simply try to turn it on, the LED flashes from green to amber a few times, then just stays amber.
If I unplug the tv and then plug it back in, when I try to turn it on,there is a "click" followed by a buzzing noise that comes from the backof the tv for a few seconds before becoming quiet. A couple of secondslater the "click" and buzzing noise comes back and then stops for good.However, the LED stays green, but I still have no video or sound.
Then if I turn off the tv again, I can't get the green LED to stay litby pressing the Power button unless I unplug the unit and then plug itback in.
Do you think replacing the Y and Z sustainer boards could cure myproblem, or does it sound more like the Mainboard or Main Logic ControlBoard?
FYI... I'd been noticing a scattering of red pixels (especially on dark scenes) off and on for a few months now.
Thanks for any help.
  • 1 more comment
  • Anonymous Nov 15, 2008
    sme problem, no power.1
  • inoxone Apr 30, 2009
    Same thing...last nite watching tv the tv popped..then no picture no sound..just flashing amber display lite.
  • Anonymous May 24, 2009
    did the problem sloved?
95% Y and Z sustainer boards since you alweady had red pixels.
Posted on Jan 19, 2009
Anonymous
SOURCE:
I have a Vizio p50hdm while watching heard a pop noise and tv went out cant turn back on.I replaced main board and power board and still doesn't come on any Ideas?
The power amplifier chip (which goes "pop" when it goes bad) may be located on the board where the IR sensor is. Sometimes (but not always) you can make the TV come on by holding the power button in _until_ the TV comes on. But that usually only works when the chip is "going" bad. If you heard the pop, it's probably shot. Also, check for a fuse on _any_ of the boards, and possibly a main fuse at the back of the TV.
Mar 09, 2016 | Vizio 50" p50hdm high definition...
Vizio P50HDM Plasma
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jun 23, 2014 | Vizio 50" p50hdm high definition...
Picture went out on Vizio P50HDM
Check you voltages before just swapping out boards. Although a YSUS is common for no picture, so is your upper and lower Y Buffer boards or the panel itself. Check youe -VSC voltage. Does it look like it is being loaded down? If so then your YSUS is not the problem. You can run the set with just the upper or lower Y Buffer boards untill the load is gone. That will let you know wich board to replace.
Jun 20, 2012 | Vizio Televison & Video
Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
VIZIO BLACK SCREEN
That problem is the Ysus board, Sometimes people will replace the Zboard at the same time. If you bought it at costco a couple of years ago you are in luck costco will refund your purchase price, costco has changed the return policy and newer tv's are not refunded, but something to look into
Jun 06, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vertical lines on 50 inch plasma
Hey did you ever get rid of the "racing stripes"?? my P50HDM now has the same problem...i know this is askin for spam but if anyone has the solution email me at ppackratt3838@yahoo.com thanks
May 22, 2008 | Televison & Video
V, Inc. Vizio P50HD Plasma Television Logo
874 people viewed this question
Top V, Inc. Televison & Video Experts
Tony Nguyen
Tony Nguyen
rostit
Are you a V, Inc. Televison and Video Expert? Answer questions, earn points and help others
