Cell Phones Logo
Anonymous Posted on May 15, 2008
Connecting blue tooth headset to PS3
I have just bought a BT-020C headset and I cannot connect this to my PS3 for some unkown reason. I have tried entering 0000 when it ask's for the pass key but it keeps coming up with an error and I am not getting any futher. Your help in this matter would be great.
JL Brown
  • Deltrotter Jun 30, 2008
    i have a problem with setting up my bluetooth connection to playstation3. it is a bt-020c and i put in the pass code 0000 and just comes up with error80010009, if you could help me that would be fantastic of you.
  • dunsmoregill Dec 07, 2008
    I have jabra headset dont no the password to use it on playstation help
Anonymous
Level 2:
  • Expert 52 Answers
  • Posted on Nov 06, 2009
Anonymous
Expert
Level 2:
Answers
52
Questions
0
Helped
35243
Points
153
The headset needs to be compliant with proper usb standards
Bluetooth version (ver 1.1, 1.2, 2.0 (2.1?)) for ps3.
makesure the headset is fully charged, and follow the user guide.
if the code is not 0000, then try 1234,, or 9999
here is the link for the connecting to ps3 guide from sony blog
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
4helpful
Need operating instructions for Jabra BT 2080 headset
ok i hope that you are trying to connect the bt device to a phone or game system or computer,the first thing you need to do is turn the power on to what you are connecting the blue tooth device to.your phone computer or game system,next you will have to put your blue tooth device into discovery mode,now most manufactures of blue tooth devices use the power button for this feature,when you turn the power on to your device keep holding down the power button for 6 to 10 seconds this will put your device into discovery mode,usually a light will remain on,then you can search or add new device from what it is you are connecting to,it will ask you for a pin or pairing code,now most manufactures of blue tooth devices use a factory 4 digit pin pairing code,they are as follows,0000,1234,9999,or 1111 enter the code and your device should pair and work with what it is you are pairring it to .i hope this helps
6helpful
Hi, My WEP460 samsung Bluetooth head set will not connect to my PS3. What do I do?
You have to make sure your blue tooth device is in discovery mode .most blue tooth manufactures use the power button by holding it down for 6 to 10 seconds while turning your bt device on ,once in discovery mode they should pair but you will need a pin or pairing code.Most blue tooth device manufactures use a factory 4 digit pin they are as follows 0000,1234,1111, or 9999 i hope this helps
25helpful
5answers
8helpful
2answers
How do I register my blue tooth model 220
The passkey should be 0000 (four zeros) and you may want to review some new information we have now:
You may want to review this guide for connecting a bluetooth headset to a PS3:
(Click here)
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
1helpful
Will not let me connect the blue tooth to my phone
ur just a ********..haha nah jk
i got the same problem. help...
1helpful
Blue tooth is not installing for the ps3
Registering
1) Go to accessory settings
2) Click on Register blue-tooth device
3) Click on Headset
4) Scan, while holding down the main power button on the headset
5) Enter your 4-digit password. The default is normally 0000
6) Done
Using
1) Go to Audio Options (under accessories)
2) Click "Connect Blue-Tooth device"
3) Change everything from "Do Not Use" to your headset name
4) Done..
8helpful
Problems connecting Plantronics Explorer 320 to my PS3.
Hold The Key On The Blue Tooth Till It Flashes Red and Blue Then Search For It. Once Its Found Click The Power Button On The Bluetooth Again.
How to make a call via OT-020C blue tooch
I have a OT-020C BT headset and once paired to my Sanyo SCP-3200 phone, I tap the power/control button on the headset and say who I want to call. The voice-recog in the phone does the rest, usually. Of course it doesn't work in noisy areas so then press [END] and manually dial the number.
43helpful
10answers
BLUE TOOTH
The name of your bluetooth headset is the OmniTech (OT-020C).
This will be slightly difficult to explain without knowing the model of phone... First off, you need to ensure that you are using a bluetooth enabled phone. You will need to enter the settings and tools menu. From within that menu, you need to find either "connections" or "bluetooth" and select. Make sure bluetooth is enabled. There will be an option to add a new device.
On your bluetooth headset, hold down the power button down until the power light stays lit. This may take 5 seconds or more. Now your bluetooth is in pairing mode.
Back to the phone, you want to hit "add new device". On certain models of phone you additionally have to select "search for devices". Your phone will recognize any headsets in pairing mode. When it is finished scanning, allow the phone to add your headset. It will ask you for the device pin code. This pin code will be 0000.
I hope this answered all of your concerns. If you are having trouble with finding the correct settings from within your phone, reply with your phone model and I can give you more detailed information!
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
