Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Viera model TH-42PV600AZ Has a black vertical line down the centre of the screen
6ya staff
SOURCE:
Anonymous
SOURCE: VERTICAL LINE ON TH-42PX70B
hi has any1 got partd for the panasonic th 42px70b i need to 2 long bottom boards that the screen ribbons plug into and the control board which the 2 long boards plug into any 1 has these parts plz email me littlestars2006@msn.com
Posted on Dec 24, 2007
micromaster
micromaster
  • 3614 Answers
SOURCE: Hi. I have a Panasonic
have you try adjusting all the settings, and checking the wire connections?
Posted on Aug 30, 2008
Anonymous
  • 92 Answers
SOURCE: Green vertical line down the screen!
Most likely the failure of the Screen.
If you purchased the product new, and have the receipt Panasonic will repair it FOC from what I understand, at least 3 years, your TV is no where near that old yet.
If you bought it, but don't have the receipt.....
Posted on Sep 07, 2009
David Low
  • 458 Answers
SOURCE: 2 yr old Panasonic Viera 37 in - has very narrow
This is a fault developing within the screen, the only remedy is to have the screen replaced, there is no exact answer to why this has happened, it is just the nature of a plasma screens make-up that sometimes a fault can develop like this within the characteristics the display
Posted on Nov 16, 2009
Testimonial: "Thanks. Might have to live with it as it sounds expensive to replace!"
Paul
  • 381 Answers
SOURCE: solid black vertical line
You could have one of three problems. One is really expensive to fix and you might want to trash the set. Thats if the panel is bad. Secondly, it could be a buffer board that went bad. Not as expensive as the panel. Finally, it could be the connection between the two. I would first take the back off and locate this board. Undo the ribbon cable2_bing.gif and clean it off a bit and put it back. If its still there, you have a deeper problem.
The buffer boards are located across the bottow when you take the back off. About 3 inches wide. Sometimes they are on the top as well.
Posted on Dec 06, 2009
How to fix vertical black line on panasonic viera th-42pz80
If you let me know in which location of the screen is located I can assist with the possible cause since the vertical line can be caused by different items based on where its located on the Screen such as center of screen, or far right side or midle of the right half side of the screen. Reply to this same post with where the line is located and I will assist you with it.
Oct 16, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Vertical line down the screen about 2 inches thick
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPING THIS WILL HELP TO SOLVE THE PROBLEM....
Aug 06, 2011 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Panasonic Viera TH-42PV60H displays vertical lines on left side of screen.\r\nThese lines flickers and changes colors. Initially was about 2cm wide and now it is about 4cm.
Either LCD transistor got moist or the video chipset got condensation. Keep TV on standby to dry it out. Unless there is also mechanical damage to the lcd screen on the edge..
Dec 15, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
We have a one yr old panasonic Ciera 42inch recently we started having a blue and pink line appear vertically down the centre of the screen, this lasted a few days and it has now turned into a thick black...
All plasma TVs have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them.
I hope this will help out in solving the problem ......
Nov 04, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic viera with vertical lines down the screen which change colour randomly
Either the buffer board is bad or the plasma panel,sometimes it coult be bad connections on the interconnect ribbon cables from the plasma panel to the buffer boards.
Mar 19, 2010 | Panasonic Viera TH-42PX80U Plasma TV
About a four inch vertical black line down the picture
More than likely the dispay panel is defective. One of the bonded address processors is defective. The processors are part of the main screen.
Sep 28, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Ive got a black line running down my screen of my brand new tv.
1" vertical line is a faulty IC chip and as it is new it should be covered under warranty. Return it or get them to replace it.
Please rate our help++++Thanks for using FIXYA
Sep 27, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Green vertical lines on panasonic viera screen
I have two vertical very thin green lines on TV how do I fix
Jun 26, 2008 | Televison & Video
there is nothing you can do.the display  panel is defective and you must replace it
Oct 28, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
97 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
