Bosch front load waher has standing water and mold inside of door gasket
Mold builds up in door gasket, where there is always standing water. I dry it out, clean the gasket the best I can. There is also black stuff building up where the detergent and fabric softener goes in.
You can try comet/ajax and limeaway and scrub it all off.It will return in time.Sorry ,You can try comet/ajax and limeaway and scrub it all off.It will return in time.Sorry ,
You can't post conmments that contain an email address.
If you have mold on the rubber gasket of your Duet front loader, I can almost assure you that you have lots of mold in other places in the machine. Front loading washing machine are almost hermetically sealed and if the door is left closed, the inside just never dries out. This is just a perfect environment for the growth of mold and other fungi. Once mold gets established in materials such as rubber gaskets, it can be very difficult if not impossible to eradicate because mold grows "roots" deep into the pores of the material, making it very difficult to remove. Eradicating the mold may result in damage to the gasket since my "cure" is to paint on full strength bleach on the moldy surfaces with a brush or sponge (wear gloves). Repeat if necessary. You may wind up having to replace the front door gasket to get all of it. It will probably take more than one application to fully eradicate the mold from the VISIBLE surfaces of the rubber gasket. If you remove the detergent dispenser and peer inside the opening, you may see a lot more mold inside the cavity. If you see mold inside the detergent dispenser cavity, imagine what the rest of the inside of your machine must look like. Do you run a periodic cleaning cycle as advised in the operating manual? Have you read the operating manual? Do you use the absolute minimum amount of HE (non foaming) detergent? Factory instructions for cleaning the door gasket call for mixing 3/4 cup of bleach into 1 gallon of warm water and applying this mixture to the affected gasket area, let stand 5 minutes and wipe the area down with a dry cloth. My experience has shown that this is a grossly inadequate concentration to deal with a deeply seated mold problem in the door gasket. To run the cleaning cycle, the factory calls for 2/3 cup of bleach to be added to the bleach dispenser. "Use of more than 2/3 cup of bleach will cause product damage OVER TIME". Initially, I would definitely consider using a whole lot more bleach than recommended and run two or more consecutive cleaning cycles. Then EVERY USE OF THE MACHINE: wipe the door gasket and all the creases and folds dry with a sponge, remove the detergent dispenser and wipe the cavity dry, leave the drawer out to dry on a clean towel, leave the door open, buy a cheapy plastic box fan and place it inside the machine and let it blow air around the inside of the machine for an hour or so to dry it off quickly, run a cleaning cycle at least once a month. If this sounds too involved or difficult, I would suggest switching to a top loading washer that is much less prone to develop mold growth as air can circulate in these types of machines to a much greater extent than the front loaders.
Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
Tips for Preventing Mold & Smelly Problems:
Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
Use softener sheets in the dryer instead of liquid softeners in the washer.
Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
Sounds like the little flexible apron just in front of your washer drum has mildewed. Take a look and see if it is holding water, and look for mold while your'e at it. Use a good bathroom mold and mildew remover to kill the mess and deodorize it.
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use
powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door
open to allow it to dry. .
You are speaking the truth there , the really sad part is all brand front load washers will have mold/mildew build up due to the rubber boot seals they all use , the only way of fixing this is soaking and scrubbing with bleach which is not a fun job to do.
until they can figure out how to get all the water out after use we will have to deal with mildew.
top load washers use gravity to drain most water out so they dont have this problem.
Phil
Front load washers are notorious for developing mold/mildew to build up because they retain a lot of moisture in the round gasket the door closes into. Wash it down with a 50:50 soulution of bleach and water. You may have to use a brush on the "hard" stuff. Occasionally, run a quick load with no clothes and just bleach through a complete cycle in the washer. After a heavy day's washinh, leave the door open a little to help dry it ou.
Hi.
The quickest way to solve your problem is to fit a new door seal.
Then each time you finish a wash, clean and dry the door seal.
At least once a week, depending on how often you wash, do a hot wash with powder, but no clothes in.
This is called a maintenance wash.
This should solve your problem.
The door seal probably got into its present condition because of several different reasons, namely:washing at too low a temperature-not using sufficient powder- amongst other things.
the mould is actually living bacteria, not a pleasant thought
Please positive feed back if you find this helpful
Cheers and good luck
Well the mold is caused from the door being shut after you arte finished with the use of the machine. it traps the mouisture inside..To solve this use some bleach and water wipe it down around the door seal..then after each load just crack the door open this will allow air to dry out the inside and stop the mold
I want something I can do.
