Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F Logo
Posted on Sep 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My freezer is blowing but not cold enough to keep it frozen
Anonymous
Level 3:
Genius:
  • Master 1,622 Answers
  • Posted on Sep 15, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1622
Questions
Helped
391581
Points
4742
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor.
Hope this help in solving the problem. take care....
My freezer isn't keeping things frozen. The inside is cold, but not nearly cold enough. Some packages of meat are spoiling. I hope that the freezer isn't a total loss. I would rath
there may be a gas leak. call the fridge technician and have it checked out.Check that the power plug is in properly and that the point is alive (blown fuse in meter box)
Jan 30, 2015 • Freezers
1helpful
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 • Freezers
I have a GE GTS 221C fridge/freezer. The fridge is working fine. All of a sudden, the freezer is not freezing. Just cold, but not enough to keep food frozen. The fan on the freezer is working.
remove the rear cover inside the freezer if it has a lot of frost on it,then the evaporator coil is frozen up and you cant blow cold air over or thru a solid block of ice,defrost it,then check the defrost heating element,defrost thermostat and timer or defrost circuitry for no power or defective components,you can use a hand held hair dryer to defrost it quicker
Jan 08, 2011 • GE Freezers
Freezer is not getting cold enough. For example, meat is still frozen but ice cream is soft.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
2answers
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
Frigidaire upright 13.7 cf
Will it freeze water? The vent coming into the freezer may be blocked. Check that and see. Is the refrigerator keeping those items cool? You may also have a vent blocked by the fan cover (dusty). If all this is right, you may have a freon leak or worse a compressor or evaporator going bad.
Food in freezer not frozen; food in refrigerator not cold
1.check the coils on the back or under side.
2.check if compressor is running
3.check if copressor is hot
4.let me know the answers
Jan 14, 2009 • Freezers
3helpful
Freezer not freezing food even at highest setting
If the unit is running continuously and not maintaining the temperature cold enough the system may have a leak. If it is NOT running continuously the problem could be in the temperature control.
2answers
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
