Every time I turn on my GE televison, the Guide Plus screen appears. I can click clear to make it go away, but I don't use it at all and just want it gone.Can you help? Thanks so much.
Try these options
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I just fixed my tv, what you do is when the automatic guide pops up, go to the right nd click review options and turn the automatic guide off
Try going back to the setup menu. If it asks for the Guide Plus, answer NO or SKIP.
I have an RCA tv with no remote. I use a universal remote given by my cable provider. The Guide Plus menu comes on each time i turn on the TV and wont turn off for 10 minutes. The cable is on, but in a small window in the upper left corner. The only way i have gotten it to Not come on, is by manually turning on the tv by hand, then using the remote for the cable. OR spontaneously disconnecting the plug from the tv to the cable, and plugging it back in. Can someone help me with getting rid of the Guide plus using a universal remote or manual controls on the tv?
There is no way to turn off that I can find. I am having the same problems, but when I go to set up of the guide plus there is no option to turn it off that I can find. Please help!
i cannot get the guideplus off of my rca52939 big screen tv no matter what i do.
