SOURCE: Women's Timex Rush Sportwatch
Try holding all of the buttons down at the same time and then releasing them. This should reset the watch. If that does not work, then you need to take the back cover off again and briefly create a short (with a metal screw driver for example) between the battery and the 'brass' casing. Hope this works for you!
SOURCE: Setting time/date on Ironman Triathlon 8 lap
Press & hold set button the seconds will flash.
Press split/reset to set seconds to zero
Press mode to select hours
Press split reset to advance hour digits go through 12 hours to get to AM/PM
Press mode to select minutes
Press split reset to advance minutes
Keep repeatin the above steps to set month date day and 12/24 hour diplay
Press set when done.
SOURCE: timex ironman triathlon - need directions to adjust time for day
Follow this link and download usars manual for your watch:
http://assets.timex.com/manuals/?timexBrand=core
Use ZOOM tool as the writings are tiny.
Do not forget to rate, please.
SOURCE: how do you set Timex Triathlon Ironman watch?
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT
