Maytag EPIC MFW9700S Front Load Washer Logo
Posted on Sep 16, 2010
F 21 - Maytag EPIC MFW9700S Front Load Washer
tip
Hi there.... I have tried the above, but nothing happens after I have clicked on...
Hi! I have noticed a lot of people have this problem that they actually forget there Sony Ericsson mobiles' Phone Lock Code. If you want to recover your phone lock code please go through the following procedure. This procedure will tell you your mobile's lock code without flashing and resetting of any kind!..
I have also have a Nokia version of this tutorial here: Nokia
Follow these steps;
  • Open this link, select your phone and download the software. (PLEASE CLICK HERE)
  • Follow the onscreen instructions to install the software.
  • Once installed, turn off the mobile and remove thebattery. Now reinsert the battery and insert the cable (DCU-60 thatcomes with the box) while holding the 'c' or '@' button on your mobile.
  • Your computer will detect a new device and install it.
  • Once installed please unplug your mobile, remove the battery. Now reinsert it.
  • Download xs++ from here
  • Extract this file and run XS++.exe
  • In XS++, click Connect.
  • Hold 'C' or '@' key on your phone and then insert the USB cable.
  • u can get some information about your phone when it's connected
  • click or tick GDFS at the bottom.
  • Then click Phone Lock, it will show you the code on right hand side. Note that code.
  • click Settings at the bottom, then Disconnect.
  • unplug the USB cable, remove then reinsert the battery.
  • You are done, enter 0000 or the Noted one (In the 3rd last step)
    If I was Helpful, Kindly Do Rate!
    Regards,
    Waqar.
    Find the y and x intercept of this equation 3x-6y=-21
    To get the y-intercept of a line you set x=0. So 3(0)-6y=-21. Solve for y: y=(-21/-6)=7/2.
    For the x-intercept, set y=0 in the definition of the function, then you solve for x.
    3x-6(0)=-21. or 3x=-21 and x= -21/3=-7
    3u/u^2-14u+49-21/u^2-14u+49
    Solution is
    3u/u^2 - 14u + 49 - 21/u^2 - 14u + 49
    =3/u - 14u + 49 - 21/u^2 - 14u + 49
    =- 21/u^2 + 3/u -14u-14u +49+49
    =- 21/u^2 + 3/u -28u + 98
    Same Problem Again - Mega Raid.... Unknown Error
    Hi
    The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
    However, the extract posted in your suggests network problems.
    Any number of physical to driver and configuration issues can result in network problems.
    Try the basic checks;
    1. Change or try a known patch cable
    2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
    3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
    4. Can you try another switch
    5. Check and load correct or latest manufacture's drivers
    Reply with more info.
    Mike
    Top Maytag Washing Machines Experts
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    ZJ Limited
    ZJ Limited
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
