<p>Bar code symbols are composed of a number of adjacent bars
and spaces of different widths of pre-defined codes. A barcode scanner is used
to read or scan the bar code symbol to represent the information to decode.
Once the symbol is scanned by a handheld reading device or another, can then be
used by computer software to track inventory and perform other functions.
Microsoft Excel is a computer application that use bar code information can
make the business perform. <br />
<p><br />
<p>1. Insert bar code scanner to your computer using the
"interface cable keyboard wedge". The keyboard wedge interface cable
looks like the printer port of your computer, and differs only in that a
connection between the scanner bar code and serial number of your computer or
USB port. The cable is provided as a peripheral pattern with hand-held bar code
scanners. <br />
<p><br />
<p>2. Open Microsoft Excel on your computer after the bar code
scanner connected to your computer. <br />
<p><br />
<p>3. Links on the Excel cell to the bar code to enter and bar
code scanning to load it into Microsoft Excel. <br />
<p><br />
<p>4. View the data in Excel file is translated into a vision
of the bar code information. <br />
Hello Norma,
you can use the suffix or prefix to send characters, which are not included in the barcodes tgehter with the scanned barcode data.
If you dont need any character before or after the data, you can leave it blank.
It is usually used to add an Enter or Tab to switch to the next line, while scanning to some application like excel.
You would need an application, which can use the scanner. If there is no app preinstalled use the DataWedge provided by Symbol on their support pages. http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=10774 You can install the whole package on the desktop PC and then connect your PDA. The DataWedge will be installed automatically.
To get scanner to work on MC9090 WM5 and scan into excel, I had to install DataWedge From Here
You will need to install this through your ActiveSync
That will make it so you can scan directly into excel
The setup your data, the you can do a find, to find the cross ref
You need to be in an application first. For example, launch mobile Excel and make sure your cursor is in a cell. When you scan, it will enter into that cell. Just make sure the cursor is in the cell you are trying to get the info into before you scan (If it's not working, the app you're running may not be compatible with the scanning function, but I've never seen this).
Oddly enough, from what I've seen, if you just scan something without having an app launch, I've seen the MC70 default to the phone function and try to dial the number scanned.
i has mc70 barcode scanner .My problem is can not scan the barcode smoothly i need scan one barcode using 15 min then the thing scanned .Please help and advise ?
