Televison & Video Logo
Posted on Sep 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i set my tv - Jensen JER-321 Remote Control
Anonymous
Level 3:
President:
  • Master 1,932 Answers
  • Posted on Sep 18, 2010
Anonymous
Master
Level 3:
President:
Answers
1932
Questions
0
Helped
519491
Points
6158
Configuring codes:
  1. Turn on the component that you want to set up.
  2. Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
  3. Release the component key.
  4. If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
  5. Within thirty seconds, enter in a 4-digit code number. The component key lights will blink with an upward motion when a code has been successfully entered. In this case proceed to step #5. If the code has not been successfully entered, the componment lights will not blink. In this case return to strep #1 and start over.
  6. Test code by pressing "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 2 and use the next 4-digit code listed.
Note: If none of the codes turn your component off, try the Auto Code Scan function.
Auto Code Scan:
The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
  2. Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
  5. Press "0" - "9" The green light will blink as codes are sent.
  6. As soon as the remote turns your component off, press the "action" key. (You have 1 second in which to press the "action" key to save the code.) The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
  7. If none of the codes turn your component off, return to step 2 and start over. Thank You
I want to learn a complete setting of it please help?
Here you are chief
How to set up your new TV - CNET
https://www.cnet.com > how-to > how-to-set-up-your-n...
Dec 26, 2020 - Here's how to make sure it's set up correctly. ... How to set up your new TV: Connections, HDMI cables, picture settings and more. Got a new ... A similar simple fix is to adjust the TV's overscan so you can see the entire image.
The Complete Guide to TV Ports: How To Hook Up Your TV ...
https://www.cabletv.com > Equipment Guides
Dec 23, 2020 - How to hook up your DVR to a TV; TV ports: best to worst. Port Glossary. Here are some phrases you ...
How to Set Up Your New Smart TV ' Tom's Guide
https://www.tomsguide.com > set-up-smart-tv,review-6...
Dec 10, 2019 - You're probably excited to enjoy 4K resolution; figure out what HDR is; and explore all the cool features of your new TV, from obscure apps to ...
How to Set Up Your New TV ' WIRED
https://www.wired.com > story > how-to-set-up-your-ne...
Dec 25, 2020 - Congratulations on that fancy OLED 4K or just really grotesquely huge television set you've got there. Setting it up should be a breeze, but ...
1helpful
How do I reset my LG 55"UHD LED LCD 100Hz Model No 55UBB850t TV. When tv was initialy set up we said yes to set top box accidentally but we don't have one. I have TV running through Austar but we ha
http://www.lg.com/us/search/srch_manuals-tab?customerModelCode=55UB8500&mobileFlag=N#
Restoring the Default Settings
mr14_home.png ">w14_settings.png ">General > Reset to Initial Settings
Delete all the TV settings data and reset the TV. All the options in the Settings Menu will be reset to the default settings.
After reset, the TV will automatically turn off and on.
Type the password to Reset to Initial Settings
Do not turn off the power during initialization.
Error: incompatible TV settings
You need to pull out the manual. The settings are related to the INPUT to the TV. You must select the DVD-CD settings from the Menu and switch from the TV setting to DVD.
How do i connect my set top box to my digital tv
Ok, I am confused. How old is the TV? If new, hook the ariel directly into the tuner on the TV. The ATSM tuner in auto configure will identify and setup the channels with no need for a set top box. On old TV using an Analog Tuner will need a box. Antenna in goes to the antenna, antenna out goes to the F connector on the TV. Should be one coax connector on the TV. That is an F connector. Set the TV to channel 3 or 4 depending on what the switch is set on the back of the set top box.
Nov 16, 2013 • GPS
4helpful
Tv went out itself red light ( power on off ) just blink, we can't turn on tv set neither fron remote or at the tv set
I set up teac HDB840 to tv- via coxial cable from wall to set top box, then rca cables output of set top box , then to input to tv.-tried av button on tv showing av1 av2 and av3 but still no picture only...
Hi, Your set top box (PVR) is running on channel 3 or 4. Go to menu and sellect a source TV, DVD
Note: Do not connect more than 1 set of cables to tv or you may damage something.
TV > box connect RCA cable or HDMI not both.
Set top box > connect RCA or HDMI Not both.
audio devices > TV connect RCA or HDMI not both.
Good luck.
TV speakers have switched off (i dont know how) how do i switch them back on again have used remote control to access sound options and does not seem to be a feature for on of off sound adjustment
Go into ur tv menu again,go to sound option again check what on the writing highlight on the tv SOUND SETTING now is it said VARIABLE SETTING.Than it is the sound setting problems,go into that highlight word VARIABLE SETTING just press the enter button on the remote to change it back to FIX SETTING.This should and will solved ur tv sound setting problems.If the sound setting already highlight word is said FIX SETTING.Than the tv have bad incomming broadcasting input signal cable or ur tv have bad or dead speakers problems to the tv itself.Not Sound Setting problems.
I'm trying to set up my Onkyo HT-r380 receiver (which came in the HT-S330 home theater system). I can get AM and FM radio to play on all the speakers. I can not get sound from my XBOX 360. The 360 is...
I looked at the manual and they provided the following settings.
To listen to audio received by the HDMI IN jacks through your TV's speakers:
  • Set the "TV Control" setting to "On" (? 37) for an p-compatible TV.
  • Set the "Audio TV OUT" setting to "On" (? 36) when the TV is not compatible with p or the "TV Control" setting to "Off".
  • Set your Blu-ray Disc/DVD player's HDMI audio output setting to PCM.
  • To listen to TV audio through the AV receiver, see "Connecting External Components" (? 17).
10helpful
2answers
Need code for asda remote model#URC20-D1F for use with my sony tv
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
Sony TV codes
010,011,028,030,031,077,107,128,131,166,203,237,302,309,367,444,445,446,449,160
To enter. Just hold SET and TV at the Same time.
The red led light stays on you are in set up mode.
Enter the first code on the list and try power button.
Keep following the steps untill you can turn the tv off.
Then its set.
4helpful
Is my tv digital compatible or not
https://www.dtv2009.gov/FAQ.aspx What you need to know is whether your TV set has something called a “digital tuner” already built in. If it does, your TV set will work after February 17, 2009. The best way to determine whether your TV set has a digital tuner built in is to consult your owner’s manual. If that’s not possible, you may be able to look up information about your TV set on the manufacturer’s website. Or, you can take an up-close look at your TV set. In any case, you’re trying to find out if your set has an input connection labeled “digital input” or “ATSC” (for Advanced Television Systems Committee, which is the DTV format).
Here are some general guidelines that may help:
TV set made before 1998 was a traditional “analog” set. If you bought a big-screen, projection TV between 1998 and 2004, it may have a built-in digital tuner inside. But chances aren’t great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
If you purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores feature digital tuners that will work after February 17, 2009. But it’s not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as “HD-ready” or “HDTV monitor” sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You’ll still need a special converter or a cable TV connection. Hope this info above helps. Also, check your manual, and if you don't have it some manufacturers, (Philips does for some models) offer the manual on their websites.
Top Jensen Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
