hi K Smith.
Here are some troubleshooting steps that may help in identifying the issue.
- Start by doing a hard reboot, remove the battery and unplug its AC adapter then press and hold the power button for 20 seconds and see if it will boot up.
- If these will not work remove the HDD then boot it up and see if it will still get stuck at the BIOS screen or not.
- If it doesn't get stuck on BIOS and boot onto a black screen that means it's the HDD that is faulty.
- If it does get stuck on BIOS even without the HDD that means it's the motherboard that is faulty.
- Last trick you can try is to remove the CMOS battery for a second then put it back in.
- If all these will not work you'll need to send it for a repair if its still under the factory warranty
or.
1) Unplug the power cord --> Remove the battery --> Hold the power button for
60 seconds --> Connect the power supply then try to switch ON the laptop and
later put the battery back into the laptop.
2) If the problem still exists then get it checked out.
or read up some more at this link.
Toshiba satellite c660 stuck on windows splash Google Search
