Question about Hoover Washing Machines
Hoover vision HD 1400 AAA, 8kg VHD 8142 - Hoover Washing Machines
  • m_a_blackham Sep 18, 2010
    was using the washer when there was a big bang and all my electrics went out.
    i turned the electrics back on and the washer started working again then after a few minutes just stopped.
    we have checked the fuses in the plug are ok and they are.
    if you turn the washer on and put it on any of thr programs nothing happens, no lights come on and all you hear is a very faint tick, tick, tick.
    i have only had this machine for just over 2 years so surley it should not have broken down yet
  • 2,272 Answers
Check if the inner drum is spinning without noise when you turn it on manually.If the same noise is heard then it can be drum center bearing,that is out of alignment/.The other possibility can be the timer ,it must be getting short causing the noise. Check out.keep updated. Thanks.
Posted on Sep 18, 2010
  • 5,081 Answers
Thank you for posting the details of your washer..Can you please explain your problem...So that i can give an solution for the problem
  • 1 more comment
  • INDIRA KUMAR
    INDIRA KUMAR Sep 18, 2010
    Ok fine...The problem can be the power supply can be burnt out ...So how handy you are in working with the internal parts of the washer?
    no idea what to do with a washer apart from use it.
    so how much would this cost to be fixed
  • INDIRA KUMAR
    It depends on the problem ..After inspecting the internal parts only the problem can be decided or it will be like shooting in the dark..Kindly reconsider the rating you have given and do accept my solution...
Anonymous
SOURCE:
I have a Hoover VHD Sensor Dry 1400 AAA that trips the house fuse each time I turn it on. What should I do?
disconnect from the power outlet and call an technician to find the short or earth leakage problem
Feb 20, 2018 | Hoover Washing Machines
How to reset the delay start on a hoover 1400 AAA vision hd
consult the manufactures website for a manual free download eric
Dec 25, 2017 | Hoover Washing Machines
Hoover vision hd
the bearing are gone
Jan 18, 2014 | Washing Machines
Hoover vision hd 1400 aaa manual
I have hoover vision hd 1400 aaa
In proble stain blaster
I oll redy clean thing and check water vest pipe
Nothing to blocking
Jun 16, 2013 | Hoover AAA140 Front Load Washer
Hoover vision hd 8kg door security button flashing
i now have same problem- did you get a solution?
Feb 17, 2012 | Hoover Washing Machines
My Hoover VHD 1400 aaa has the front concrete weight off
This weight helps to balance the machine. needs to be put back on or replaced. Machine will not operate properly without it.
Mar 28, 2011 | Hoover Washing Machines
Not working at all. my washer was on working and i heard a big bang and my electrics went off, i turned everything back on and the washer started up again but then stopped and now will not work. when...
The ticking that you hear is probably the timing motor for the dial.
Was the "bang" from outside the house? If so, then a transformer probably blew and hit your house with a power surge. Motor is likely damaged, and will need replacement.
If the bang was inside the house, the capacitor on the motor probably blew (unusual failure mode though), and will need to be replaced, motor is likely damaged as well.
Sep 18, 2010 | Hoover Washing Machines
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Feb 01, 2010 | Washing Machines
Washing Machines Logo
715 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
