Never ever go thru puddles-cause u dont kno how deep it is-and can ruin an engine--do not try startin it till u kno theres no water in the engine-u can bend a rod-liquids dont compress--chec dip stic and then take a plug out to spot water in cylinder-take ur time--if these are ok then the electric system is soaked and you need to dry out
You have a firing issue .. replace complete spark system plugs wires distributor cap rotor button and coil what happened is you got it wet and coil broke down water got inside distributor cap and messed it up .. you might even have to go as far as to replace the entire distributor
