SOURCE: installation disc
Here u go sir :
http://www.opendrivers.com/company/2287/lexmark-free-driver-download.html
and let me know if u get help?
SOURCE: need help on my lexmark x 4270
If you are with a lexmark printer switch to windows xp or just try to buy another printer... If you are using this x4270 printer probably it is famous for faxing problems so probably you must not try to fax...Try lexexpress if you are in warranty
SOURCE: Installation of a downloaded driver for Lexmark X1290 All-In_One
For those of you who have downloaded the appropriate vista driver for your printer. Go to device manager on pc (control panel, hardware and devices etc) Select uninstall printer driver, as you want any old references to xp one deleted. Now, place new disc or dicc with new driver files in and your install new hardware program shopuld self start. IF not you can manually do it by going to add new hardware wizard, and select own information to suit yopur needs. But win vista should automatically find the new drivers.
I bought a Lexmark X1290 printer and installed a wrong driver (for WinXP) from the enclosed CD. Then I could not run the All in One program. After many reinstallation attemps, I finally found a solution (which is unfortunately quite hidden at the Lexmark website):
1) Unplug the printer's USB cable from the computer.
2) Download the cleaning utility from ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/.
3) Double-click on the cleanup utility and follow the on-screen instructions to run it.
4) Restart the computer.
5) Download all files from ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/reg/
6) Follow the instructions in the "Vista BackDoor Instructions.txt" and delete all remaining Lexmark
keys in the registry.
7) Restart the computer
8) Download a proper driver for Windows Vista from the Lexmark website.
9) Install the driver accordingly to the instructions (it's important to plug the printer's USB cable when you are ask to, not before)
The problem with Lexmark Unistall and CleanUp Utility is that you cannot delete all Lexmark registry keys while you arelogged in the system. This is anellegant way how to circumvent the problem.
