I had to change the battery on my Laguna, only problem is once the new battery was fitted the car alarm stopped working. I have checked the fuse for it, that was ok, then i went to see if i could have a look at the actual alarm, but have absolutely no idea where it is. From my understanding the alarm comes as standard, so i thought i would have a look at the manual, but the is no mention about the alarm system.
Has anyone got any advice? Any help would be appreciated.
Many Thanks
alarm goes of when un lock car
Hola mi nombre es Cesar vivo en Venezuela, poseo un Laguna 2.0 16v y presenta la siguente falla: Cuando el vehiculo calienta, funciona erraticamete, se apaga al acelerar, (mas con el AC encendido). Tambien se acelera solo en relanti. Tengo como sopechosos 4 elementos: "bomba de combustible, micromotor de marcha minima, potenciometro TPS y por ultimo lo unico que pude haber dañada por manipulacion, una valvula electronica asociada al vacio de la camara impelente, la cual desconosco su nombre. es plana y tiene una coneccion electrica y una toma de vacio
