No!
First, how old is this fan, and secondly is it exhibiting symptoms of low oil? If it is, just adding oil is not enough, you should change the oil in it, by removing the fan, placing paper towels (lots of them) around the part which the blades attach to and turn the fan over dumping the oil into the paper towels.
If it is not having problems and you just want to top it off, use either the Hunter fan oil, or a product called "Zoom Spout Oiler" Both are a 10wt Turbine oil. I have also used 5w20 engine oil in these fans with no ill effects, but I don't recommend it.
If you have any more concerns, don't hesitate to ask.
Here's the manual to your fan.
http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/41121.pdf
