Usual problem is the Channel A amplifier has burned and blown the switching transistors. Usually an internal board arc occurs and unless very skilled at board work of clearing the burned area and replacing the components you are better to replace the HCA2400 amplifier module... about $160
Probably the A circuit has burned capacitors or transistors. A good electrician would replace the faulty parts. Another option is to check the fuses, on the rear panel of the Behringer. Maybe this can be a simple case of replacing a burned fuse by a new one.
