ASUS M2N-MX Motherboard Logo
Anonymous Posted on Jan 22, 2018
I have bought acme wireless mouse model MW01 and i have motherboard asus m2n-mx, windows 7 ultimate installed (legal). Then i put mouse adapter into usb , windows cant recognize it. I think, that the chipset drivers for usb is too old. Suggest how to update it, because i cant find anything usefull.
Mike Teter
Level 2:
Habit-Forming:
New Friend:
  • Expert 56 Answers
  • Posted on Jan 22, 2018
Mike Teter
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
56
Questions
0
Helped
3224
Points
124
Try the manufacturer's website for a driver.
5 Related Answers
Anonymous
  • 19 Answers
  • Posted on Jan 09, 2008
SOURCE: ASUS M2N-MX MOTERBOARD DRIVERS FOR WINDOWS 2003 SERVER
u can download this from ASUS mobot site .
Anonymous
  • Posted on Feb 21, 2008
SOURCE: about lan driver asus-m2n-mx-se
http://dlsvr01.asus.com/pub/ASUS/misc/utils/Nvidia_Chipset_Raid_v6533_32bit.zip
that workd for me
Anonymous
  • 6487 Answers
  • Posted on Oct 21, 2008
SOURCE: asus m2n-mx motherboard driver
You can go to this link for all the driver download for this motherboard http://support.asus.com/download/download.aspx?SLanguage=en-us&model=M2N-MX
Don't forget to rate the solution FIXYA thank you......
teknowolf
David Preston
  • 207 Answers
  • Posted on Nov 11, 2008
SOURCE: With ASUS M2N-MX mainboard, ATI Radeon 7000 Series problem.
Your Motherboard has an onboard video chipset made by Nvidia. Nvidia and ATI have a history of not playing nice with each other.
I have 2 possible solutions for you.
1.) Remove the Radeon card and use the Nvidia onboard card (Essentially a Geforce 6100)
2.) Enter the bios (Usually done by hitting <Delete> or <F12> while the computer is booting up) Your Motherboards manual can tell you for certain. Then find the options for onboard video and disable it.
Then boot up the PC, When it say starting Windows press <F8> to bring up the windows boot menu. Select "Start in Safe mode" Once this loads up open the device manager, look under "Display adapters" find the entry for the Nvidia adapter, right click on it and select either "Uninstall" or "Disable this device"
Which you choose depends on your personal preference Whether you like Nvidia or ATI boards better.
If it makes your decision easier a Geforce 6100 is roughly equivalent to a Radeon 8500 in performance.
I hope this helps
Dave
Anonymous
  • 110 Answers
  • Posted on Nov 27, 2009
SOURCE: DRIVER NEED FOR ASUS M2N MX SE PLUS FOR WINDOWS XP
Dear! Please go to www.asus.com and give your motherboard's Number in search bar and download your motherboard's driver and istall it and ready to use it easily.
My M2N MX SE PLUS MB with AMD Sempron LE 1200 ( 2100 Mhz)1 GB RAM windows 7 Ultimate shows blue screen and restarts when playing games/videos. I use 1080p full HD Viewsonic 22 Inch monitor on 1980/1080...
Windows 7 requires One Gigabyte of RAM to even run. You are most likely running out of memory when you're playing games and/or watching video. I would suggest upgrading your memory on your computer, if you're on the cheap, or if you can afford to do so, invest in a new machine.
Hi..i installed Windows 7 but i dont have the sound driver. My motherboard model is: M2N-MX SE PLUS. Where can i get it as free download?
http://drivers.softpedia.com/get/BIOS/Asus/Asus-M2A-MX-SE-Plus-Bios-0406.shtml
Please open the link above and click the download button.
After instaling windows 7 nothing back from my speakerd
This motherboard is an old model, and may not work with windows 7 completely.
If you have the CD that the motherboard came with, insert it and search for audio drivers. Otherwise search this website for any appropriate drivers: http://support.asus.com/knowledge.aspx?SLanguage=en&p=1&s=24&m=M2N-MX&os=&hashedid=0pKBwEIE8tqMT4j7
Hope that helps.
2answers
Windows 7 sound card drivers
http://support.asus.com/Download.aspx?SLanguage=en&m=M2N-MX%20SE%20PLUS&p=1&os=
try here, if the drivers you require are not available for windows 7, try the older drivers but run them in compatibility mode when installing
2answers
I installed Windows 7 in the Asus M2N-MX series motherboard but could not load audio drivers. Where can I dowload audio driver from?
The drivers for Vista should work just as well for Windows 7. This is true with almost everything about Windows 7; in fact, Windows 7 is actually NT kernel 6.1! (Vista is NT kernel 6.)
1) Go here: http://support.asus.com/download/download.aspx 2) Type M2N-MX into the search box on the left. 3) Select M2N-MX from the results. 4) For your OS choose Vista 32-bit if you installed the 32-bit version of Windows 7 or Vista 64-bit if you installed the 64-bit version. 5) Have fun.
Good luck.
4helpful
Drivers for win 7
*This motherboard dont have a driver for Windows 7 however you can download the Windows Vista driver for you Windows 7, If youre using Win7 32bit download WindowsVista 32bit for Win7 64bit use Vista 64bit.
Download Here
*Product Type: Motherboard
*Select Series: SocketAM2/AM2+/AM3
*Model: M2N-MX
*Operating System: Depends on your OS
*Chose which driver you want to install and download.Thanks for using Fixya.
Asus m2nmx does not support additional ram in win 7
That motherboard supports up to 4 GB. Make sure that the sticks are exactly the same and are put in the first socket of each channel.
23helpful
4answers
Asus m2n-mx audio driver for windows 7
Go to asus website.. if dont have for windows 7 use vista drivers. if W7 prompts warning just ignore and continue install..
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
