Wow that is very strange indeed. Not sure if someone has suggested it yet or not, but have you tried a reset in the method of unplugging the power from the source for a good 3 minutes, then replugging it in? So let me verify, no functions on the remote work at all right now? That is very very strange, there should be no button you can press that does that. It sounds like this machine is experiencing hardware problems for sure.. but let me know more.
Let me know and I can help!
Tim
To reset the machine to factory settings it's easy - just press the power button from the case for 15 seconds and the unit will shutdown - unplug it from the wall after that. Wait one minute and restart. After that you will have to reconfigure it.
Of course you have checked that the tv is set to receive the signal from the Loewe recorder and its remote is set on REC.
I have assumed that the unit behaves the same when you press the buttons on the case. In that case the problem is hardware, not software - the firmware was corrupted. Pressing on some buttons on a remote has nothing to do with it - it fails because the processor chokes. You must take it to a service shop for a proper fixing, reloading a new firmware is not such a thing.
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Dear Azraelsri, I was sceptical about this response as I've tried this numerous times. (It says 5 secs in the manual). Each time I press the power button it powers up and down in a cycle but never goes to red light (off). This time I have pressed the button for more than 15 secs, but same thing happened. Unit did not power down but seemed to cycle through high and low power settings without ever turning off. I lifted my finger and switched the unit off, then turned off at the wall and unplugged. I waited over a minute and restarted, but still can't reconfigure. Can't reconfigure from DVD unit and remote is still not talking to DVD. We have checked remote batteries and believe it is sending a signal as red light on remote lights up when buttons are pressed (eg: REC or DVD or MENU) but nothing happens. No instructions are appearing on screen to enable reset. Screen remains black. Abigail
(Comment posted 3 hours ago but still waiting for reply)
