Question about Sharp AR-C260M All-In-One Printer
Network Error CE-02
Im having trouble scanning a document having it send to my desktop. I keep getting the error Network Error (CE-02). Do you have idea how what that error stands for?
  • Anonymous May 22, 2008
    Network Error CE-02 problem, i can not scan and email image to my desk top.
Error ce-02 means that the computer the image is being sent to is not running sharps "network scanning tool" which is part of the sharpdesk software suite
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_0c6af8f6331df718
Posted on Jun 25, 2008
I'm having the same problem. i managed to make a new profile on my computer, but the copier still has old profiles stored on it. how do i wipe out the old profiles?
Posted on Jul 14, 2009
  • 4 Answers
CE-02 says that the copier can't find the IP address it's been told to send it to. You had your workstation set on DHCP instead of locking it on static, now the copier can't find it because it's still using the IP address you sent it when you created your scan profile. Either lock your workstation on a static IP or get a local DNS server involved, wipe out your scan profiles on the copier, put the local DNS server IP in the web page, and resubmit your profiles from the scanner tool on your workstation.
Posted on Mar 17, 2009
  • steven_v Feb 10, 2010
    You have to go the copiers web page and wipe out all the old profiles. Then resubmit then from the Network Scanner Tool. If the copier comes back with an error message, wipe out and recreate the profiles from the NST.
    New Friend:
Hey, had the same error about two weeks ago. Make sure that what ever device your are trying to open your scanned files allows port #### to be open in the firewall. Naturally you would assume that it is but i spent two weeks circling around that result.
Posted on Sep 26, 2011
Sharp says something to do with truning off the windows fire wall but its not really well know if it works or if its safe.
Posted on Aug 13, 2008
    New Friend:
  • 5 Answers
Check your SMTP server set on the copier. Chances are it's wrong. Also check the SMTP relays if there are any.
Posted on Nov 30, 2009
Posted on Sep 02, 2009
You can edit your profiles by typing in the ip address of the copier in your browser. This should bring up the settings of the copier. Then click on "destination" that will show you all the profiles and settings
Posted on Aug 11, 2009
I am getting this error but the softwere is running. I've tried rebooting both machines and checked the IP address it's sending to with no luck. Any other sugestions?
Posted on Jul 16, 2008
You need to restart your exchange server because there may be updates and your exchange server didn't accept it. Good Luck
Posted on Oct 22, 2008
6ya staff
SOURCE:
What is Network error (CE 02) thank you
Network Error CE-02 - this is where the machine cannot communicate with the SMTP Gateway / Mail Server for scanning. Check that you have a connection with the network and that you have the correct SMTP I.P address.
If you are using a host name for the mail server make sure that you have configured the DNS entries correctly.
Hope this helps.
Feb 01, 2011 | Sharp AR-M455N Copier
Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
Feb 03, 2010 | Sharp AR-BC260 Color Copier
Network error CE-02
You didn't tell me enough about the problem. Are you trying to scan from a PC or to a PC? The problem is that the network address changed when you moved the printer. You can fix this by correcting the network address
Nov 23, 2009 | Sharp AR-M162 All-In-One Laser Printer
Server unavailable error
Ah, the dreaded CE-00 and CE-02. This is a networking problem!!
It means the IP address stored in the copier for the computer you're trying to scan to is old and stale!!! That workstation got its IP refreshed by DHCP and your copier has been left in the dust!
To refresh the workstation's scan profile information in the copier either:
1) Reboot the workstation, or
2) Find the Network Scanner Tool icon in your tray, right-click on it, find Automatic Profile Update, and click on Update Now.
Also check the webpage and make sure that if you're using DNS for name resolution that you have the correct and working DNS IP's!!
Jul 07, 2009 | Sharp MX-2700N Color Copier
Getting a CE-02 error when trying to scan.
1) Check that the Network Cable is
inserted properly.
2) Check that the connected network
supports TCP/IP protocol.
3) Check from the Web Page that the
Primary/Secondary E-mail Server
Address or the Destination FTP server/
Desktop PC address are properly set.
4) If the above address is described with
Hostname, check that the DNS server
is properly set.
5) Check that the SMTP server/FTP
server/NST causes a trouble or not.
Jun 10, 2009 | Sharp AR-275 Copier
Error code CE-02 when in the scan mode.
the FTP server cannot be found. This is a network error. If it is connected to a network, check with your IT person to set up the FTP server.
Apr 13, 2009 | Sharp AR-M455N Copier
Network Error code CE-02
the ce-02 code is just a communication error it general in nature so you could have a couple different issues going on
Apr 09, 2009 | Sharp AR-168D Black and White Copier
CE-02 error code when scanning on SHARP MX-M550U copier
ce error means not hooked up property to your email server
Feb 12, 2009 | Office Equipment & Supplies
Network Error CE-02
There is a Windows Port that is being blocked. First make sure the IP it's scanning to and IP on the machine are the same. disable the firewall. I'm working on narrowing down the port now and will post as soon as I find it.
-Mike
Oct 31, 2008 | Computers & Internet
Network Error on display
Have you setup your smtp address on the machine? From any workstation in the same network open your web browser. Key in the IP address of the mfp copier. Goes to network setup and key-in your smtp address.
Sep 14, 2007 | Sharp AR-M277 Black and White Copier
Sharp AR-C260M All-In-One Printer Logo
32,409 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
