SOURCE: Toshiba 42HP66 Picture fades in when turned on
To start, the module with the blown fuse will have to be replaced. The rest of the boards will have to be verified to know which other ones may have been the cause of the failure.
You will have to give the set out for factory service to have it working again.
Jerry G.
SOURCE: LCD tv main/digital board
Send it to us and we will refurbish the board.....
e-mail [email protected]
SOURCE: Can I replace my LCD panel on my Toshiba REGZA
You could as the part number for the panel is 75011258. However it runs about $2500.00...Your best bet is to replace the TV.
SOURCE: Toshiba 42hp66 has sound but no picture
Part of the power supply is in protect mode. There is most likely a short or something failed on one or more of the boards.
The service rep would swap out boards to locate the fault. Then he would leave the new board(s) in the set, and perform any necessary adjustments.
Take the set in for an estimate before approving repairs. There are many times these sets are not worth serving when they are out of warranty.
Jerry G.
SOURCE: Toshiba 37HLX95 wont power on, just click sound
I have the same problem. It happened once before about 4 years ago just after I bought it. I put a DVD in without the power on. I was able to take it out and it worked fine. This time my daughter put the DVD in, I took it out but still no picture or sound.
Have you had any luck?
