Nokia 5310 Cellular Phone Logo
Posted on Sep 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
5130c SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! SIMLOCK_DATA corrupted!
Anonymous
Level 3:
President:
  • Master 2,360 Answers
  • Posted on Nov 29, 2010
Anonymous
Master
Level 3:
President:
Answers
2360
Questions
0
Helped
669334
Points
5015
It may be due to network lock, contact service provider , else you can get unlock codes here http://www.mobile-unlocker.com/nokia-5130/rs2wp9/
Nokia 3110 10 second auto off solutions
If the phone restart itself after few seconds frequently this problem occur due to enable or Watch Dog Timer (WD timer) so at this stage we need to repair Super Doungle by using some repairing tools likeMX KEY/Turbo flasher etc.To fix this if you are not a mobile tech better to contact mobile repairing shop.Good luck "Thanks for visiting fixya"
7helpful
My nokia 6500 slide phone getting switch off automatically every five minutes.. pls give solution
When we do check bus with MXkey this message will show. SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. This error can only repair with MXKEY via internet.So the best way to solve this problem is to concern a good mobile tech.Without going to repairing shop it cannot repair.In case if you are a mobile tech pl reply let me give you the procedure.
48helpful
7answers
NOKIA 3110C PHONE RESTRICTED SOLUTION
Hi, nokia 3110c phone restricted problem. please help.
6helpful
2answers
I have a nokia 5130c there is problm camra on stand by please help me
Tools & Materials required  :
  1. Mxkey Dongle with latest software installed
  2. UFS / JAF Box
  3. Nokia 5130c Fbus cable
  4. CA-101 Usb data Cable
Step By Step :
  • Backup RPL & PM
  1. Open Mxkey Software
  2. Select UFS / JAF as Interface, then connect it.
  3. Pick Nokia Module
  4. Pick BB5 Tab
  5. Pick Service Tab
  6. Connect Phone to UFS / JAF box using Nokia 5130c Fbus Cable
  7. Click on " backup RPL "
  8. Save to safe location.
  9. Pick PM Tab, read full, save to safe location.
  • Flashing / Firmware Updating via CA-101 Usb data cable
  2. Select Nokia Usb Rom as Interface
  4. Pick BB5 Tab
  5. On flashng Tab, Pick Nokia 5130c Latest Firmware Package Properly.
  6. Click on " Flash " Tab
  7. Connect Phone to PC via CA-101 Usb data cable.
  8. Wait Until All Process done
Here's the log operations :
Reading phone`s ID ...
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
productData saved.
Restarting phone ...
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 24E0000D70D27D5657572DFFD11A84578F44242B
ASIC MODE ID: 00
 SecondaryBoot: rap3gv3_2nd.fg [BB5]  version: 9.11.1 revision: 0.0 size: 0x3C00
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982  - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM]  version: 9.50.0 revision: 0.0 size: 0x23010
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Reading RAP NPC (0x168 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Flash Imei: 35422303116811
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to "C:mobileEx.4dataackupRPLBB5_35xxxxxxxxx_BACK.rpl"
Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010)
Processing file: rm495__07.97.mcusw as MCU
 [BB5,BB5 ALGORITHM]  size: 18.20 MB
 Supported RAP Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsucNokia USB Flashing Generic, ID: 1FB998E3
RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
RAP EM0 ID: 00000296
RAP EM1 ID: 00000B22
RAP PUBLIC ID: 24E0000D70D27D5657572DFFD11A84578F44242B
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
RAP ROM ID: 273F6D55DFAAF68F
[ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
[ADL] Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes
[ADL] Device found: nmwcdnsucNokia BB5 ADL Loader USB Generic, ID: 8572D57
[ADL] Verifying communication to device OK.
Erase size: 21.00 MB
CMT NOR area [00000000-000006BF] erased in 0.500 s
CMT NOR area [000006C0-0001FFFF] erased in 0.515 s
CMT NOR area [00040000-000BFFFF] erased in 2.172 s
CMT NOR area [000C0000-0013FFFF] erased in 2.094 s
CMT NOR area [00140000-0137FFFF] erased in 1 min 17.812 s
CMT NOR area [01380000-0151FFFF] erased in 6.954 s
Flash programming ...
CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written.
Programming completed in 1 min 5.172 s
Processing file: rm495__07.97.ppm_x as PPM
 [BB5,BB5 ALGORITHM]  size: 7.72 MB
Erase size: 8.62 MB
CMT NOR area [01520000-01DBFFFF] erased in 37.188 s
Programming completed in 26.469 s
Processing file: rm495__07.97.image_x_red as CNT
 [BB5,BB5 ALGORITHM] page size: 128 K size: 12.89 MB
Erase size: 34.00 MB
CMT NOR area [01DC0000-0215FFFF] erased in 22.829 s
CMT NOR area [02160000-03FBFFFF] erased in 3 min 12.922 s
Programming completed in 45.125 s
[ADL] Restarting phone ...
[ADL] Device found: nmwcdcNokia 5130 XPressMusic USB Generic, ID: 1878DB02
Flashing completed in 9 min 5.000 s
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.97 13-09-10 RM-495 (c) Nokia
Imei plain: 3542xxxxxxxxxxx
Product Code: 0578115
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
Imei net: 354xxxxxxxxxxx
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 9 min 8.922 s
I cant switch on my phone nokia3110c , every time i tried to switch on it says CONTACT SERVICE
hi,
your phone have a software problem and its cause is "security test failed"thats why it has a contact service status...by fixing that you need this gadget ...
1.mx key activated dongle with ufs interface
2.3110c fbus cable (same as 3500c and 6300
3.)modified pm 1 and 309 of 3110c
procedure...
a)open mx key
b.)connect the phone to mx key using fbus cable
c.)in mx key select bb5
d.)bus check and you you will see this logs
SIMLOCK_TEST passed
SECURITY_TEST failed!
in this logs you will noticed that security _test is the only failed...
e,)we will continue by selecting PM then thick PMM authentication
f.)then your pm now is authenticated ,write the modified PM (by writing modified pm ,thick load from file ,then write)
g.)after writing PM here now is your phones logs...
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
h.)now you need to unlocked the phone by clicking ,SERVICE ,IMEI and SECURITY then INIT SIMLOCK...and you phone is done
always remember ,when doing software action to your nokia phone ,always back up the rpl to prevent more damage..thanks for trusting fixya..
1helpful
I have an 3310 with trouble sim card not accepted
maybe your phone is locked by operator.
if your phone network is open lock or not locked by operator it may come from the phone security validation.
3110c is Base Band 5 series or we usualy call BB5.
this phone have security inside the Rap3G and the Nor Flash.
if the data inside the Nor Flash not match with the data from Rap3G then the phone imei will be 1234565454
321?
but the phone should be accept the sim card if only the imei is corrupt.
why? cause the simlock data is writen in the Permanent Memory or PM group 308.
so if the phone reject the sim card maybe the PM 308 is corrupt.
forcing erase phone can make the data inside NOR flash like MCU and security (IMEI and the PM 308) erased from the phone.
after refaslh the phone, the phone will alive but the security data is removed.
and when the watchdog inside the phone found the phone dont have the correct data, then the phone will automaticly shut down in 30 minutes. if you put charger on phone, it will faster the WatchDog timer to 3 minutes, or you play the music from the phone it alsi faster the WD timer to 3 minutes.
how to recover the security data?
read ASK data (Ask Security Key) and send it to the Nokia and it will be RPL data and write this data to your phone.
this ASK to RPL services is not free, and you need dongle to make this job.
7helpful
5answers
I want to codes
LG SECRET CODES:
LG all models test mode: Type 2945#*# on the main screen.
2945*#01*# Secret menu for LG
IMEI (ALL): *#06#
IMEI and SW (LG 510): *#07#
Software version (LG B1200): *8375#
Recount cheksum (LG B1200): *6861#
Factory test (B1200): #PWR 668
Simlock menu (LG B1200): 1945#*5101#
Simlock menu (LG 510W, 5200): 2945#*5101#
Simlock menu (LG 7020, 7010): 2945#*70001#
Simlock menu (LG 500, 600): 2947#*
LG-U81XX SPECIAL CODES
Code to read phone version :
- Phone without SIM
- Enter 277634#*# or 47328545454#
- Select 'SW Ver.info'
Code to reset phone :
- Phone without SIM
- Select 'Factory Reset'
Code to enter UNLOCK MENU :
- Phone wit SIM inside
- Enter 2945#*88110#
Test Menu 8330 : 637664#*#
Test Menu 8180 V10a: 49857465454#
Test Menu 8180 V11a: 492662464663#
Test Menu 8130-8138: 47328545454#
Test Menu 8110-8120: 277634#*#
MOTOROLA SECRET CODES
On the main screen type
IMEI number:
*#06#
Code to lock keys. Press together *7
Note: [] (pause) means the * key held in until box appears.
Select phone line - (use this to write things below the provider name):
[] [] [] 0 0 8 [] 1 []
Add phonebook to main menu:
[] [] [] 1 0 5 [] 1 []
Add messages to main menu:
[] [] [] 1 0 7 [] 1 []
Copy SIM memory (phonebook menu):
[] [] [] 1 0 8 [] 1 []
Eng Field options (main menu):
[] [] [] 1 1 3 [] 1 []
Slow (Frequency of search menu):
[] [] [] 1 0 1 [] 1 []
Medium (Frequency of search menu):
[] [] [] 1 0 2 [] 1 []
Fast (Frequency of search menu):
[] [] [] 1 0 3 [] 1 []
Enable EFR:
[] [] [] 1 1 9 [] 1 []
Function :
[] [] [] # # # [] 1 []
Change pin:
[] [] [] 0 0 4 [] 1 []
Unblocking using the "puk" number:
[] [] [] 0 0 5 [] 1 []
There are lots of similar codes exist. If you change the last number to 0 you can deactive that code. The 3 digit number at the middle are from 0 to 999. I put the most interesting codes. (EFR):Enhanced Full Rate Codec.
You can change GSM frequencies to 900/1800 by entering the enginnering model. Following the below steps:
enter menu and press 048263* quickly, then you will enter the secret engineering menu
under "Opcode"
input 10*0*3 for GSM 900
10*0*4 for GSM 1800
10*0*5 for GSM 1900
10*0*6 for dual band GSM 900/1800
10*0*7 for dual band GSM 850/1900
To add extra message space 4 your Motorola C350 C450 C550 or C650, press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.You will receive an extra 50 msgs memory space.Switch phone off and back on.(not tested)
NOKIA SECRET CODES:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that supports WLAN like N80
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
*#7328748263373738# resets security code.
Default security code is 12345
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin#
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.)
Press and hold "0" on the main screen to open wap browser.
5helpful
3answers
Forgot my lock code
remove the sim and enter *2767*3855# then wait for 1 minute your phone gone restart him self then your phone is free
Apr 05, 2008 • Cell Phones
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
