Does your LG KE850 Prada work only with your current service provider or, when you insert a SIM card from another network, do you see any of the following messages?
Enter Subsidy Code
Enter Subsidy Password
Enter SIM Unlock Code (Simlock)
Contact Service Provider
Insert Correct SIM Card
Wrong SIM Card
Incorrect SIM Card
Phone Restricted
Can't Undo Restriction
Locked Return For Service
Enter Unlock Code
Enter Special Code
If so, your LG KE850 Prada is LOCKED and we can help you remove this lock on your LG KE850 Prada in a few simple steps, allowing you to use your phone on any GSM wireless network anywhere in the world.
You will not have to mail in your LG KE850 Prada. No Hardware or Software required. No technical knowledge required at all. Simply provide us your LG KE850 Prada’s IMEI number and we do all the rest. Three Simple Steps
Simply provide us your LG KE850 Prada’s IMEI (which can be found by typing *#06# into your phone), during check out.
After order placement, the Unlock CODES together with easy to follow instructions guides will be sent to your email address within the time frame given.
This is a small tutorial on how to hard reset the lg prada on request for forgotten security code.
Turn the prada on without a simcard and wait for the insert sim screen.
On the touch screen hit call, after enter this code 2945#*#. and you will see a menu pop up headed "Engineering menu".
scroll down to factory reset hit that and wait for it to reboot.
i have lg prada ke850. 'unlocked' cell phone, and just received in mail and activated. as soon as i turn it on, it shows 'locked'. i hit the unlock side key but nothing changes. pls send me a solution. lg manual is here but so poorly written i cant understand. even it does not show cervice center in usa nor it has index page in the back. worst manual i ever seen.
Try the SIM in another phone. SIM cards go bad.
If it doesnt work in the other phone it will have to be replaced. I
THis can also be caused if you set up a PIN code and it was entered in wrong too many times and you did not use the right PUK code to unlock it. THis will permanently damage a SIM card.
f it does work in another phone then your phone is no longer able to read SIM cards. Check with the manufacturer for warranty info.
