Televison & Video Logo
Posted on May 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony KP-57 hw40 red picture tube... manufactured 2002
IF I WERE TO FIND A RED PICTURE TUBE ON E-BAY OR SOMEWHERE IS IT POSSIBLE TO INSTALL W/OUT AN EXPERT TECHNICIAN?
Sonny Berry
Level 3:
  • Master 8,617 Answers
  • Posted on May 19, 2008
Sonny Berry
Master
Level 3:
Answers
8617
Questions
Helped
1723096
Points
23750
Yes you would need a service manual and have to do all the alignments but it would need to be an exact match on the picture tubes as some sets have different components within the same mode year depends on serial number so be sure the replacement tube has the exact tube numbers that your tube has. it still is a very involved proceedure and the picture tube can and will hold a very serious charge and it can give you a severe shock if not handeled properly and discharged properly.
I have blue arched lines and blue screen
HI:
Your problem is the blue CRT or picture has gone bad, you will need to have the picture replaced, there are three tubes in this model rear projection television. Red, Green, and Blue. Replaceing the blue tube is the only option for normal operation to resume. It may be hard to find the tube, but you can try contacting this website for the part www.vdc.com, they manufacture and usually have stocks of sony picture tubes and rebuilt ones as well. The company's name is Video Display Corporation...
The screen turns red until it gets to a point that there is no picture
You either have a defective red picture tube or a red video drive board. Best to have a tech look at it and verify this.
3answers
Sony kp-57 hw40 has no picture and the stand by
most likely the flyback transformer is bad t8005.
2answers
Picture turned red then tv turns off
The red picture tube is bad, you must replace before it cause damage to the boards.
1helpful
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Sony KP-53V45 color issues
When ever a tube starts to short or is shorted set always will have over bearing drive lines then shut down like RED if it was bad, set would come on long enough for red lines across set then shut down this is the same with all 3 tubes.Also if you think it might be green tube disconnected green CRT board on neck of green tube if set comes on and plays then it is green tube do all 3 tube this way one at a time this will tell you if you have other problems.
Red lines flashing red then blacksout
Their is only two possible things they are Bad Red picture tube or video ic on red CRT board more then likley its your Red Picture Tube.
Sony Rear Projection TV - Red tube too strong
remove the front speaker assembly and the small access panel behind it and you will see a small square control assembly with 6 dials on it 3 control the color guns and 3 control the 3 gun focus. Try turning down the red control slightly they will be set up just like the CRTs red green and blue.
3helpful
Sony 57 in Rear Projection TV
If the picture is playing fine and you notice that the background is getting more and more red, until it is too red and the set shuts down, it could be that the red screen control is set just a bit too high. If this is the case, you can probably correct this yourself. If you are watching a perfect picture and then it suddenly flashes a very bright red, with thin red lines in the pictureand then shuts down, it usually means that the red picture tube has developed a short in it, between the cathode and heater. A good tech might be able to remove the short by arcing, but if the short persists then the red tube will have to be replaced. Either way, this is something that should only be done by a qualified tech.
Red Screen
Sounds like the red color tube is goeing bad you wil hafto call in a tech to conferm it Sony is noted for tubes goeing bad, in the future leave sony alone
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
