Cect p168 problem internet & MMS settings with Rogers Canada
I can't seem to get my internetand mms working with rogers canada.
I also made sure that I had a data plan.
I just bought a Cect p168 and I can't access internet (it says connection failed) and also my mms don't work at all! These are the infos I received with my phone to configure it: Internet
for rogers canada http connection type proxy setting 208.200.067.150 proxy port 8080
You have to create the data account..
***First Step*** 1.Main menu –> Select Services 3.Select Data Account –> Select GPRS 5.Select the first entry 6.Edit the account name to whatever you would like 7.Edit APN to media.com 8.Edit Username to media 9.Edit Password to mda01 10.Edit Auth Type. to Secure 11. Save
Select Back –> Select Back
SMS and MMS
For SMS: Message Settings>common settings >check reply path go back then to Pref Bearer change to Prefer GSM
For MMS: Message Settings>server profile Select any profile Activate profile then Edit Profile Rename Profile> whatever you want, i chose Rogers MMS Homepage>http://mms.gprs.rogers.com Data Account> rogers Connection Type > HTTP Proxy address: 172.025.000.107 Proxy Port: 8080 Username: media Password: mda01
Are they good for my area (montreal), because I entered them exactly has above and it really doesn't work...
I just bought a Samsung Armani P520 from overseas and my internet does not work either. I cant download ringtunes from the text msgs.
I also tried the setting changes above and no difference still cannot connect says service unavaible.
PLEASE HELP!!!
THanks
ChantelleHi there, I am with rogers canada (BARRIE ,ON)
PLEASE HELP!!!
THanks
Chantelle
AnonymousApr 04, 2009
i have the same problem i can not access internet on the cect p168 it keeps saying connection failed, HELP im with Rogers
AnonymousApr 06, 2009
i have same problem to get on the internet but i live in wales !!i have same problem to get on the internet but i live in wales !!
AnonymousMar 20, 2014
Looking for data (internet and MMS) APN settings for Straight Talk wireless on my Samsung Galaxy Mega GT-I9512. Can anyone help?Looking for data (internet and MMS) APN settings for Straight Talk wireless on my Samsung Galaxy Mega GT-I9512. Can anyone help?
AnonymousMar 31, 2014
how do you edit your sript underyour username when you type your name inhow do you edit your sript underyour username when you type your name in
You can't post conmments that contain an email address.
***First Step*** 1.Main menu --> Select Services 3.Select Data Account --> Select GPRS 5.Select the first entry 6.Edit the account name to whatever you would like 7.Edit APN to goam.com (lowercase), if not work, try "internet.com" 8.Edit Username to wapuser1 9.Edit Password to wap 10.Edit Auth Type to Normal 11. Save
Select Back --> Select Back
***Second Step***
Select WAP 1.Select Settings --> Edit Profile 3.Select the first entry --> Edit Profile 5.edit the name to whatever you would like 6.Edit Homepage to http://mymobilehomepage.rogers.com 7.Edit Data Account to the Name you established in the First Step 8.Edit Connection type to HTTP 9.The IP address is 208.200.067.150 and the port number is 80 10.Edit Username to wapuser1 11.Edit Password to wap Select back or done Select Activate Account
MMS
Select Messages --> MMS --> Message Settings Select Server Profile Select the first entry Select Edit Profile Edit Rename Profile to whatever name you would like Edit Home Page to http://mms.gprs.rogers.com Edit Data Account to the same data account you created for WAP Edit Connection Type to HTTP the IP address is 172.025.000.107 and the port is 80 Edit the Username to media.com Edit the Password to mda01
Select Done or Save Make sure to activate the profile and you are good.
I found this in the internet, why couldn't you do the same? No IPhone app. works with the Sciphone, sorry.
Now try thiese settings:
Setting's name: Rogers Homepage: mymobilehomepage.rogers.com Session Mode: Permanent Connection Security: Off Data bearer: GPRS GPRS access point: goam.com IP Address: 208.200.067.150 Auth Type: Normal Login Type: Automatic User Name: wapuser1 Password: wap
***First Step***
2.Select Data Account --> Select GPRS
4.Edit the account name to whatever you would like
5.Edit APN to wap.cingular (lowercase)
6.Edit Username to [email protected] (UPPERCASE)
7.Edit Password to CINGULAR1 (UPPERCASE)
8.Edit Auth Type. to Secure
9. Save
***Second Step***
Select WAP
2.Select the first entry --> Edit Profile
3.Edit the name to whatever you would like
4.Edit Homepage to http://device.home
5.Edit Data Account to the Name you established in the First Step
6.Edit Connection type to HTTP
7.The IP address is 066.209.011.032 and the port number is 8080
8.Edit Username to [email protected]
9.Edit Password to CINGULAR1
Select back or done
You should now see a Black [G] in the upper left of your screen.
To access the net select Services --> WAP --> Homepage.
If it connects the Black [G] should turn Green
MMS
Select Edit Profile
Edit Home Page to http://mmsc.cingular.com
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to [email protected] (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
For all of you guys out there that need to setup your internet on the cect I9, using att service.
apn: media.com username: media password: mda01 mms.gprs.rogers.com
ip 172.025.00.107
Rogers internet.com settings (to use phone as modem. Or is needed for HTML phones, or wap 2.0 phones at this current time. requires access to a Data access plan
PLEASE HELP!!!
THanks
Chantelle
