Yamaha Full-Size Keyboard Logo
Anonymous Posted on Sep 21, 2010
Yamaha Clavinova CVP 55 - the floppy drive is not recording as it should.
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Sep 21, 2010
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3798916
Points
33142
Hello. Most likely you will need to either clean the drive or replace it.
Does the base detach from the Yamaha CVP-601 for transportation
The Yamaha CVP-601 can be transported fully assembled. However, yes, it can be disassembled if desired.
Your owners/operators manual will detail the procedure.
Click here if you do not have one: Yamaha Clavinova CVP 601 Owner Manual Assembly Preparation Before...
Need manual for CVP-700 english version
how opening yamaha cvp-700
Jun 30, 2012 • Music
2answers
The disk drive on my Yamaha Clavinova CVP-105 acts like it has a disk in it when it doesn't and won't always play pre-formated disks like it used to. Is the drive dieing? Where can I go to get it fixed? ...
Often these drives are continuosly selected by the controller and rotate even without a disk.
These USUALLY use the old 720K disks which are almost impossible to find. The common 3.5 1.44Mb floppies often will not work in these units.
You can SOMETIMES use the 1.44Mb disks by covering the second corner hole AND degaussing the disk with a tape eraser and then reformating the disk in the Clavinova.
The pre-formatted 1.44Mb disks without degaussing SOMETIMES leaves artifacts between the tracks used by the 720K disks that causes problems.
Yamaha clavinova cvp-83s
Hi, did you manage to sort your problem as the same thing has happened to my clavinova (same model). Thanks.
2answers
I have a clavinova CVP 409. If I try to record using an external memory device (external Hard drive or memory stick, a message appears; DISC ERROR. Can you please help me solve the problem or direct me...
I SUSPECT that the CVP 409 will ONLY talk to the Yamaha USB floppy drive, not a hard drive or memory stick.
The internal drivers for these musical instruments do not have the "smarts" to talk to the wide variety of peripherals that PC's are able to.
1helpful
Can I replace the pedal unit to the Yamaha Clavinova CVP-75?
I can't solve the problem, but just wanted to sympathize because I have the same problem. My pedal is broken on my Yamaha Clavinova cvp85a. It worked wonderfully for years but finally it broke.
I'd be in the market for buying a new pedal or fixing the old one. But I've not found any suggestions in any of these forums for either solution.
Yamaha Clavinova CVP-83S NO SOUND OUTPUT
clavinova 83s...comes on but goes off within 20 sec.,sometimes comes on display lights up but no sound or functions?
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
