SOURCE: 40 inch lcd blue line vertical
Have just purchased Samsung LA32R81BD have thin blue vertical line a third into the left hand side of the screen. A pity no support on a sunday or public holiday! Tried the squeeze theory without joy. Will attempt swap and see what excuses the dealer has? Thanx for advice fixya!
SOURCE: update problems
put the two files "ypp2.rom, ypp2.rsc" both in the root and the folder "datecasts" before you upgrade
SOURCE: YP-P2 FIRMWARE PROBLEMS
I had the same problem!
But I found the fix for it after much searching.
First, download the latest firmware directly to your computer's desktop from the Samsung website: http://tinyurl.com/3j4su4
The file is a Zip one so : make sure you extract the 2 files to your desktop!
-Connect your P2 to your computer and go to My Computer.
-Double click the YP2 icon.
-Copy the 2 extracted files from your desktop into the open window. (Do not put them in an already existant folder).
-Unplug the connection from your computer and restart your player.
It will do an update and shut down. Restart it a second time and it will finish the second update.
- There you go, it should work no problem.
The firmware update from having your player connected to the Samsung Media Studio 5 for some reason doesn't work properly.
By doing in manually it works just fine.
The update link I provided is for a US based player.
Just go through the Samsung site to find an update for other contries if you need too and follow the same directions I give above to solve your issues.
Hope this helps!!!
SOURCE: i updated my lcd samsung firm ware and the picture went crazy .
you need to go into the service menu and adjjust the option bytes. When you upgraged you changed them. The other solution would be to replace the main pcb
