Nokia 5130 Cellular Phone Logo
Posted on Nov 17, 2017
My nokia 5130c-2 v06.94 screen is becoming dark & is sometimes getting hanged. Even while connecting to a charger, it is not getting charged. The mobile switches off and again to restart it takes a lot of effort. Is it a problem with the software? Is there a problem with the hardware? The phone is one and a half years old.
5 Related Answers
Anonymous
  • 32 Answers
  • Posted on Aug 17, 2009
SOURCE: my phone not connect by pc suit software
there are four solutions, 1-select offline mode
2-check the data cable 3-format your memory card(because there might be virous) 4-update your phone software using mobile internet
Anonymous
  • 107 Answers
  • Posted on Apr 16, 2010
SOURCE: Forget my mobile security code(Nokia 5130c XM)...Plz Help
4745066750 try this. it is your master code, hope it helps
sanjay dixit
  • 117 Answers
  • Posted on Jan 14, 2011
SOURCE: my mobile nokia 5130c-2 problem
TAKE TO NOKIA CARE CENTER THEY WILL DO THE MASTER RESET FOR YOUR PHONE
Anonymous
  • 131 Answers
  • Posted on Jun 28, 2011
SOURCE: i update software of nokia
i think your mobile boot file is damage or dead go to repair shop i hope it is helpful to you please vote me please
Anonymous
  • Posted on Jul 09, 2011
SOURCE: my nokia 5130c-2 phone getting
Instal anti virus
My nokia 5130c-2 starts charging automatically when i put in the battery without connecting the charger, then the battery discharges in a few hours..... pls help me.
There might be some battery issue you need to replace this battery to another one and please don't left your mobile while you are charging battery cells going to dead if its over charge and you will going to lose your battery and mobile as well Laptop Rental Laptop Hire in UK Wales Ireland and Scotland Hire Laptops
7helpful
My nokia 2330c-2 is always low on battery even after I have charged it and it most at times hangs and goes off automatically
HI, IT IS VERY POSSIBLE THE BATTERY IS BAD OR YOU COULD CHECK YOUR CHARGER...IF THE BATTERY IS BAD IT WILL DISCHARGE VERY FAST AND IF THE CHARGER IS BAD, IT WILL TAKE LONGER TIME TO CHARGE OR NOT EVEN CHARGED AT ALL.THE ISSUE OF HANGING COULD BE THAT THE PHONE HAS TOO MUCH LOAD ON IT PRESENTLY THAT IS MORE THAN IT CAPABILITY...SO, YOU COULD TRY DELETE SOME THINGS ON THE PHONE..
CHEERS
2helpful
10helpful
4answers
How to format china phone nokia 5130c-2 made in
Go to setting option than choose back to factory setting with code 1234 or 1122 or 3344.
30helpful
5answers
1helpful
Phone was working fine then battery went out of charge,when I got home I PLUGED IN MY CHARGER AS NORMAL BUT NOTHING I HAVE TRIED SEVERAL TIMES TO GET TO GHARGE BUT NOTHING.
Try these and tell me the result.
1. Try to charge from a different charger.
2. Use another battery and try to on the phone.
3. After plug on the charger press power on/off button for a while. If nothing happened on your mobile after use these 3 tips then visit Nokia service center for installing the operating system on your phone. If the OS is corrupt then the mobile going under dark. No movement, no signaling of charging nothing. Even you can't update it from internet right now. Because the phone memory is fully dead. Its happened with all mobiles if the OS corrupt. Its was happened also in my Nokia N73.
Thanks &waiting for your reply.
3helpful
My nokia 5130c is not supporting nokia pc suite
Not able to connect ur phone. Thats Wierd.
well connect ur data cable to pc & phone. when u do so, u'll get options on ur phone like
1. PC Suite Service
2. Mass Storage & all..
select PC suit service & then its done.
but for PC suite service, u need nokia pc suit on ur pc too..
88helpful
6answers
How can i connect my nokia 5130 c 2 to my pc
Iam unable to conect my 5130c 2 to pc through data cable as the driver cd not supplied with the pack
Phone hangs when connected to charger
Sounds like a problem with the battery. Is it a problem to make a telephone call and do you have a humming noise?(gsm sound)?
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
