SC901 is a problem with the copier's mechanical counter. Either the counter is bad, the board that it interfaces with is faulty, or there is a problem in the connection between the two.
Other than providing an incorrect count, this error shouldn't keep you from using the copier. If it does, it shouldn't be expensive to have the counter replaced.
Hope that helps!
Error sc901
